Smoke on acceleration
Old Aug 27, 2004 | 08:04 AM
3greenfordsagain's Avatar
3greenfordsagain
Question Smoke on acceleration
While driving my wifes Excursion last week I noticed on a hard acceleration that I put out an incredible amount of smoke. It only did it once for me but my wife, I think she drives it harder than I do, says it happens all the time. Is this normal or an indicator of something that I need to be worried about?
Old Aug 27, 2004 | 08:18 AM
mjwhip2's Avatar
mjwhip2
What color is the smoke?
What sort of mods have you done?
It is not unusual for a substantial amount of black smoke, under hard acceleration, to be emmitted especially when chipped.
Other colors though could be a sign of something going wrong.
This is from Steve Baz's website:
White smoke:
Caused by unburned fuel passing through the engine. Some white smoke is normal on cold start-ups. Excessive white smoke could be an indication of inoperative glow plugs, loose injectors, low compression from worn rings or bent connecting rods, or coolant leak into the cylinders--head gasket or injector well sleeves.
Black smoke:
Caused by excessive fuel for the amount of air drawn into the cylinders. Some black smoke on hard accelerate or at higher altitudes is normal. Excessive black smoke could result from restricted intake or exhaust, inoperative leaking or weak turbo, intake hose(s) leaks, leaking or worn injectors, fuel return or supply restriction, stuck Exhaust Back Pressure Regulator valve or solenoid. Also PCM inputs such as BARO MAP ICP or EBP sensors.
Blue or blue/white smoke:
Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods. Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, worn or leaking injector o-rings, thermostat stuck open, oil consumption, or plugged crankcase depression regulator valve. Also PCM inputs such as MAP or ICP sensors.
Steve Baz's site -Great reference site
Mike
Old Aug 27, 2004 | 08:42 AM
3greenfordsagain
Sounds like it is normal black smoke under hard acceleration. It's actually kind of cool to see a big cloud of smoke behind you blocking out the road. Thanks for the help and info!!
Old Aug 27, 2004 | 12:19 PM
Fire Rooster's Avatar
Fire Rooster
Yeah I like to smoke out the people who flick their cigarette buts out the window. "you wanna smoke smoke this"
Fire rooster
