help
Old Jun 10, 2016 | 10:41 PM
Jack Dressler's Avatar
Jack Dressler
help
have a 92 5.0 hundred fifty thousand miles exhaust coming up through the intake just a bad valve or bad rings what's an easy diagnosis
Old Jun 11, 2016 | 07:39 AM
ng19delta's Avatar
ng19delta
If you have exhaust coming up through the intake, it will be a valve issue. It sounds like either the valve is sticking open, or jammed open. Perhaps something got inside the valve cover, and worked its way into the guide. In any case, do a compression check of the engine- preferably a bleed down (Engine static, and you feed line pressure in through a calibrated gauge set) and look for the low cylinder. This will tell you which valve to look at. Additionally, you can pull the valve covers off, and motor the engine, and look for the one which does not fully close, or appears not to move, although the rocker arm moves freely... Most likely you will need to pull the head to repair the valve: It could also be a bent valve stem causing a bind.
Your rings should have nothing to do with this: If they are leaking, the exhaust would be pressurizing the crankcase, and you would see it coming out the oil fill (among other places) if you removed the cap while the engine is running.
Scott
Old Jun 11, 2016 | 12:56 PM
'89F2urd's Avatar
'89F2urd
How did you verify that the exhaust is coming up into the intake?
Egr could be stuck open as well.
Old Jun 11, 2016 | 01:05 PM
Jack Dressler
.smoke out of the oil fill tube dipstick and breather
Old Jun 11, 2016 | 01:10 PM
'89F2urd's Avatar
'89F2urd
That is not exhaust in the intake, that'd be blowby or a clogged pcv.
Old Jun 11, 2016 | 03:56 PM
Jack Dressler
sounds like it's time for a rebuild appreciate your time partner any tips on the rebuild
Old Jun 11, 2016 | 07:50 PM
'89F2urd's Avatar
'89F2urd
You don't want tips from me unless you have a lust for power and have some money you'd like to get rid of....
Not so fast though, check compression and pcv valve first before you jump to the rebuild conclusion, clogged pcv will cause gasses to go back through the intake (oil in intake/airbox) and excessive smoke out of the oil fill.
Old Jun 11, 2016 | 08:09 PM
Jack Dressler
.I love the power little bit of moneywould you suggest a little bigger cam maybe 202 heads I can't go all out but I can sure go a little in PCV valve that's fine haven't done a compression test yet probably tomorrow one dry and one wet? Been awhile since I've done one actually looking forward to it! Have three trucks and there all down right now. 92 flare side 92 f150 both with 5.0 and a 2500 dodge ram wanna build something so I know what I got going on under the hood
Old Jun 11, 2016 | 11:33 PM
ng19delta's Avatar
ng19delta
DEFINITELY NOT a valve issue- That would be "blow by": again, do a leakdown type of compression test to find which cylinder it is. This will require at least a partial teardown: If you are going to do it anyway, may as well go whole hog & rebuild the engine.
Scott
Ornonic
1978 - 1996 Big Bronco
Mar 31, 2013 07:01 PM
lexasgs400
Feb 20, 2012 11:27 AM
poboy
Jul 18, 2006 06:50 PM
seizure911
May 23, 2005 11:09 PM
MercM47
Jul 15, 2004 07:35 PM
