Brake pads
Old Jun 13, 2016 | 06:27 AM
JOHN2001's Avatar
JOHN2001
Do you happen to have an egt gauge in your truck? My old SD would eat brakes like no tomorrow just like you describe. Once I installed an egt gauges I could tell when I had a brake tying up because my temp went up 200 degrees
I never noticed anything else different until either I seen smoke come off of one or pulsating pedal. One time my wife was driving getting off the expressway, touched the brake and it almost put her into the guard rail!
What I did was put all new rotors, calibers, rubber lines and EBC yellow stuff at all 4 corners. I also found when I drained the fluid that the brake fluid was green.... I also had ceramic pads and all my problems went away once I did all that
Old Jun 13, 2016 | 07:02 AM
Macmathews's Avatar
Macmathews
Yes.. I do have an EGT gauge.. I recently thought I had a sticky caliper , but long story short I had a seized stub axle u joint on 1 side..
Changed both sides and way smoother now.
I recently had the truck up in the air and am able to spin all wheels / axles without drag.
Kyle
Old Jun 13, 2016 | 08:23 AM
JOHN2001's Avatar
JOHN2001
Next time you drive it when you get out walk around the truck and put your hand close to the rotor. Don't touch it! You should be able to tell any obvious difference. If you have a heat gun even better. Something is definitely out of place here with your truck
Old Jun 13, 2016 | 07:51 PM
z31freakify's Avatar
z31freakify
One thing 99% of people forget to do is flush the brake fluid, if not your gonna go thru calipers.
Old Jun 13, 2016 | 11:21 PM
Macmathews's Avatar
Macmathews
I did a gravity type flush, but it's been about 5 years now
Kyle
1950gmcelc
Jun 15, 2014 10:18 AM
Flawless_X
Oct 2, 2010 11:19 AM
mcassel1
2004 - 2008 F150
Aug 23, 2010 02:25 PM
BOA66
Mar 3, 2006 12:59 AM
boulderdentist
Apr 12, 2004 12:53 PM
