should I have to use pliers/crowbar to change lights on newer rangers?
Hi,
I just picked up a '11 model and one high beam is out. Manual is useless but I found you tube videos on how to change lights...at least for older versions.
there are supposed to be 2 tabs you lift to remove assembly. One is fine but the other, least what I think is the other will not bulge and I don't want to break it if they have changed something on the newer versions.
both sides are like this..I can bump up one tab but not the other...
Thanks..
Thanks..
Greywolf
1983 - 2012 Ranger & B-Series
03-23-2006 02:11 PM
moose94
Appearance & Dress-Up
09-30-2003 07:44 AM
