DUI distributor
Old Jun 4, 2016 | 10:16 PM
belshe92's Avatar
belshe92
DUI distributor
been looking at some parts for my fe so i can run around while i save coins and hunt for goodies on my cummins swap and happened across the Davis unified ignition hei conversion for my fe so my question is this, are any of you guys here running these if so how do you like them? my original distributor works just fine but i have to have some head work done and i figured while everything is appart why not upgrade from points and join this century.
Old Jun 5, 2016 | 12:41 AM
84espy's Avatar
84espy
I have one on my 460. The reason for the swap was the wiring rats nest under my hood and I wanted to clean it up. It has worked flawlessly. If you type HEI in search you will see all the pros and cons according to our members here.
Old Jun 5, 2016 | 12:47 AM
belshe92's Avatar
belshe92
i'm not to ashamed to admit that the thing that caught my eye the most was the clear cap.....
Old Jun 5, 2016 | 01:07 AM
co425's Avatar
co425
Had and stil have that distributor on the 460 that was in my truck. Works flawlessly.
Old Jun 5, 2016 | 01:09 AM
belshe92's Avatar
belshe92
is it worth the money in your opinion? 350 bones is a decent chunk of change for me....
Old Jun 5, 2016 | 05:46 AM
jimmyz469's Avatar
jimmyz469
I swapped a HEI in my truck after having intermittent ignition problems. I talked with a few friends who are mechanics and got different answers from each of them. I swapped the HEI in and eliminated a lot of wiring and the problem was gone. I think the only draw back is I had to grind my t-stat housing down to clear the much bigger distributor and when I swap my t-stat out I will have to pull the distributor out. But I'm still happy with it and the much cleaner wiring under the hood.
Old Jun 5, 2016 | 05:02 PM
co425's Avatar
co425
Yes I think it was worth it. A. For the cleaner wiring, and B. For the easier starting. Plus they curve the distributor for the weight, rpm, cam, etc. My main reason was P.O. Hacked up wiring with continued problems throughout the ignition system due to that.
Old Jun 5, 2016 | 08:18 PM
belshe92's Avatar
belshe92
gotta love PO's huh? i keep finding ghetto that i have to fix or remove on my truck.....
Old Jun 6, 2016 | 03:51 PM
skeeter1971's Avatar
skeeter1971
I like my HEI
No problems
grind the neck
spacer for the air filter
Old Jun 6, 2016 | 06:36 PM
co425's Avatar
co425
The above brings up something I forgot. You may have to clearance your water neck for the cap. I ended up buying one of the flat sided necks and grinding a small amount for clearance.
Old Jun 6, 2016 | 11:15 PM
belshe92's Avatar
belshe92
Certainly gives me food for thought
Old Jun 7, 2016 | 09:36 AM
usuallybowtie's Avatar
usuallybowtie
I bought one of the cheap offshore units off of Fleabay for $69 and run it in my 360 FE. It arrived ready to plug-and-play. It claims to have a lifetime warranty. I am not holding my breath on that but it seems solidly built and has worked flawlessly so far. (your experience may vary)
fiftysixfordf250
Jun 23, 2011 09:16 PM
68horses
Apr 9, 2009 11:46 AM
68 ranger
Sep 21, 2008 08:40 PM
jcs17
Jan 5, 2005 06:42 PM
erikl85
Jan 11, 2003 09:35 PM
