Help..plz!
Old Jun 9, 2016 | 02:06 AM
Brnfree's Avatar
Brnfree
Ah! I get it. You ran it off the starter cable lug. Very clever and there's no question about it getting plenty of power! I may have to do mine that way.
I had a stater solenoid fail in such a way that the bypass wire remained hot. I came back to my truck with a dead battery and burnt wiring. Seems a prior owner had replaced the 20 gauge fusible link with something heavier. If I wired it like you describe that couldn't happen.
All I know is ford used a fusible link and not a fuse on the bypass because of its slow burn properties (otherwise why not a fuse?). Makes me wonder if the initial 12 volt jolt helps wake the pump up and get it moving?
All in good fun and thanks for the learning! Here's a simple schematic showing the relative location of the resistor wire and other electric fuel system components in my single tank 86 E350. Can't vouch for the color coding.
Old Jun 9, 2016 | 06:47 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Brnfree, there is no diode in your diagram and power from the fuel pump relay will try to run the starter motor.
Since the starter's current draw is so high it will melt the fuselink.
The resistor wire is going to get pretty hot too.
Old Jun 9, 2016 | 09:25 AM
Brnfree's Avatar
Brnfree
Thanks Ard, I see what you mean. Unless I add the diode I'll leave it on the I terminal!
kr98664's Avatar
kr98664
I'm confused. Are you talking about the wiring diagram shown in post #16? I'm not seeing the path you've described that will try to run the starter motor. A cursory review looks good to me, but I haven't dug in too deeply.
Awaiting enlightenment...
Old Jun 9, 2016 | 09:34 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, post #16
If you shift the bypass wire to the starter cable lug, power will flow from the shutoff relay following the path of least resistance through the starter motor to ground.
The 20Ga. fuse link is then going to melt because it is FAR too small to carry the current the starter motor wants, and as long as there is oil pressure the relay will remain closed.
Old Jun 9, 2016 | 10:43 AM
kr98664's Avatar
kr98664
Yes, post #16
Okay, but not as the wiring diagram is currently drawn, right? I must have missed the comment about moving the bypass wire to a different lug.
As Emily Latilla would have said, "Nevermind..."
Old Jun 9, 2016 | 10:54 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sorry for any confusion.
Really I should have quoted his post and snipped all but what I was addressing.
That's a pita on my phone, as you lose the thread -and any context- on mobile, so I just responded inline to the post above.
Lngbeard
15
Apr 29, 2016 11:24 AM
Onus
Oct 1, 2011 09:36 AM
LARIAT 85
May 25, 2007 10:49 AM
jpjahn
Electrical Systems/Wiring
Apr 20, 2006 10:09 PM
Hegemon
Sep 29, 2004 08:47 AM
