'88 F250
Old Dec 21, 2001 | 08:44 AM
motmcd's Avatar
motmcd
'88 F250
My '88 F250, 351W looses power when engine warms up. Runs great on cold motor, however. Have spent good bit of time and $$$ without success. Most sensors are new. Compression good etc. Have scoped 3X and each time no faults etc. Fuel pressure good. Any suggestions? Please!
Old Jan 2, 2002 | 07:54 PM
madman666's Avatar
madman666
'88 F250
Check the timing; make sure it is 10 degrees BTDC.
Make sure you remove the spout connector before setting the timing, and then connect it after you’re done.
Old Jan 2, 2002 | 10:51 PM
bwamx's Avatar
bwamx
'88 F250
Well don't get to excitied, I don't have the answer BUT Iv'e got the same symptoms on my 88 5.8 F-350. It started after I installed a new long block. Iv'e checked all the sensors also. Is your truck completely stock? Mine has a K&N airfilter , JBA headers 3" catback
exauhst . I runs great untill it warms up to temp then it seems to get doggy but still runs ok. What have you changed or checked lets see if we can work through this.
Bob
88 F-350 5.8 C-6 4x4
Old Jan 22, 2002 | 07:31 AM
motmcd's Avatar
motmcd
'88 F250
[updated:LAST EDITED ON 22-Jan-02 AT 08:32 AM (EST)]Thanks for reply, Bob. I have done the following:
Cat. Ok
Fuel pressure OK
No intake leak
No vacum leaks
New: Fuel filter
O2 sensor
Temp. sending unit
MAP sensor
EGR sensor and valve
Thermostat
Timing was checked, injectors cleaned, and complete tune up. Runs better, especially now with winter temps. However, still looses power when warm. Compression shows minor blow-bye in one cylinder.
Any ideas?
PS: motmcd@att.net
Old Jan 22, 2002 | 02:36 PM
JW 4x4's Avatar
JW 4x4
'88 F250
themicro
Dec 3, 2006 05:07 PM
broncobob
Oct 27, 2006 05:35 PM
harris2108
Dec 8, 2005 11:38 PM
kane
Oct 1, 2004 12:11 AM
Dave 69_88 F Series
Jan 10, 2003 05:36 PM
