Bronco xlt 87 Crank no start error code 23 23 Throttle Position Higher Or Lower Than Expected
#31
Resistances look good, 2Ω & 8,220Ω
But the voltages should be the other way, 12V starting/cranking - 9v running... recheck when you can.
Any ignition switch work done?
For a quick check, if you have some small alligator clips & a few feet of # 18 wire, jump 12V from the battery to the + side of the coil while cranking.
#32
#33
I read somewhere the other day that Ford 302 sparks should be COPPER not platinum. Problem solved LOL.
I know this was not my original problem, which was fuel pressure but it took me a long time to figure this out because the guy who sold me the sparks recommended platinum sparks so I ruled the out as a possible cause.
Again thank you very much for your input, I learned a lot :-)
All the best Thorvar
rcb1031
19
03-19-2015 03:56 PM
simmonds1970
15
02-24-2012 10:44 PM
