ignition on electrical
Old Jun 3, 2016 | 05:16 PM
Cameo 57's Avatar
Cameo 57
Where is the best place to tie in a switched power supply buss bar?
Id like to mount a bus bar to feed relays and I am used to old chevys where there are extra 1/4" male pins on the fuse panel. any suggestions?
Thanks
94 F350 7.3 IDIT RWD A40D
Old Jun 3, 2016 | 08:00 PM
Macrobb's Avatar
Macrobb
If you intend to pull a lot of amperage off of it, why not just get a heavy duty relay, something like this. You can then run a nice heavy-gauge wire from B+ to that, and from that to your buss bar. Add a fuse somewhere in the system, just in case.
The relay doesn't draw much, so you can just tap into the existing switched power somewhere.
Old Jun 4, 2016 | 06:43 AM
tjc transport's Avatar
tjc transport
i ain't rite
i draw rite off the battery and go to circuit breakers into relays. then out to whatever i am powering.
switched power to the toggle switches to turn the breakers on and off comes off a fuse tap off a switched fuse in the fuse box.
Old Jun 6, 2016 | 12:40 PM
Cameo 57's Avatar
Cameo 57
That is my plan, but my question is where is the best place to pull the switched power from?
is there an extra spade connection someplace a guy can connect to or do I need to splice into a circuit?
Thanks
Old Jun 6, 2016 | 04:15 PM
tjc transport
i ain't rite
any switched fuse will work as long as you are only triggering relays.
i put a fuse tap like this one: on the radio fuse if i remember correctly
they have new and better now :
Old Jun 7, 2016 | 02:50 PM
Chevy_Eater's Avatar
Chevy_Eater
That's the first I've seen of that new style. Pretty cool!
fatregexp
2011 - 2019 Explorer
Nov 6, 2018 07:43 AM
tx2sturgis
28
Sep 29, 2015 06:57 PM
gnwalker
Electrical Systems/Wiring
Jan 28, 2014 11:49 AM
Immortal_Ben
Mar 8, 2009 10:00 PM
mzimmers
Dec 8, 2004 06:53 PM
