Are the front doors of a crewcab and a STD cab the same? I have a std cab parts truck and need a passenger side front door for my crewcab. What about power windows/locks...does it all bolt into manual doors, or do you have to find power doors?
Thank You
Thank You
Simple answer is front doors from 1980-97 will swap. (bronco, f150, f1250, f350, reg cab, supercab, crew, etc)
The internals changed a little from 80-86, 87-91 and 92-97 and can easily be swaped out
This seems like a good time to do a little hijacking. . .
I lost the right-front door panel in a small house fire back at Christmas time. Will a door panel from gen 9 truck fit the gen 8 truck? The above posts imply that the panels are interchangeable but I wanted to check on that specifically.
Will they swap? YES(if you do not have power windows/locks). Will they look right.... NO
