2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
What to do Next
Old Jun 2, 2016 | 07:03 AM
rakar's Avatar
rakar
Trailering
What to do Next
I have a 2007 Expedition with 98K miles on it. I had a heater hose break yesterday. The one that has the tee in int. The tee cracked and anti freeze was everywhere. Replace the hose. Before we I discovered the hose was broke the truck was running ruff and the check engine light came on. It threw a #2 miss fire. After replacing the hose and getting coolent back in it was still running ruff. I pulled the #1 and #2 coils and they were damp. I dried them off. Truck was running better and did not throw a code. Several hours later we had a 40 minute drive and just did not seem right. But did not throw a code. Drove back home and it threw the P0302 code during the last 10 minutes of the drive. I pulled the number 2 coil and it looked dry. Drove it to work 40 minute this morning and seemed fine...hesitated a couple of times under load but did not throw a code. Not sure what to do next...
Old Jun 4, 2016 | 04:12 AM
k9education's Avatar
k9education
If something was leaking into the plugs, it may have fouled the plugs. Have you replaced the plugs at all? If not, this might be a good time to replace them all. A full set of 8 will run you $65-80 depending on where you get them from. They're easy to do yourself, but if you have the 2-piece plugs have the removal tool on hand just in case they break. You may also want to check the coils, especially those first 2. You can get a tester for ~$20.
Old Jun 11, 2016 | 01:01 PM
pdqford's Avatar
pdqford
Originally Posted by rakar
I pulled the #1 and #2 coils and they were damp. I dried them off...
Did you look down in the holes to see if the plug wells were flooded with coolant?
bohiaa
May 2, 2013 08:46 PM
MOSPARKY
Oct 11, 2011 11:52 PM
vics97xlt
Apr 27, 2007 03:23 PM
Brew
13
Jul 10, 2004 10:02 PM
DHW
1997 - 2003 F150
Jun 22, 2003 09:09 PM
