Differential work
Old Jun 1, 2016 | 10:05 PM
Buck268's Avatar
Buck268
Differential work
Planning to use some bonus money this year to upgrade from my stock open rear end in the '11. Its naturally a Ford 9.75 and I just scooped up a eaton posi (now a discontinued model, but uses clutch packs which share common applications) on a killer deal and I am VERY tempted to try this myself... though common sense and experience are saying otherwise.
I am familiar with the procedure, and have tinkered around on 8.8s in the past, though with limited success. Has anybody swapped their diff before? Were you lucky enough for a plug-and-play install reusing shims? I would replace the carrier bearings/races but I haven't had any issues with my rear and would try to leave everything else intact.
I know its a long shot, but looking for success or failure stories to sway my plans.
Old Jun 2, 2016 | 03:21 PM
NASSTY's Avatar
NASSTY
The stock shims should work. momtanaman and I both installed Eaton Truetracs and both used the stock shims. I purchased a shim kit because I thought I'd need it but I didn't. Just doing a carrier swap is pretty straight forward because you don't have to touch the pinion gear.
Old Jun 2, 2016 | 03:55 PM
Buck268's Avatar
Buck268
I knew I had read a post or two of people doing that. How close were your before and after measurements? Did you use new carrier bearings?
Old Jun 2, 2016 | 08:03 PM
NASSTY's Avatar
NASSTY
What measurements? You mean the side shims for the carrier?
I didn't measure nothing. I put the side shims back in on the same sides they came from and they fit exactly like they fit with the stock carrier.
I used new carrier bearings on the Truetrac because I wanted to leave the carrier bearings on the peg leg/e-locker so I can just slap it back in when I trade the truck in.
Old Jun 2, 2016 | 09:01 PM
Buck268's Avatar
Buck268
Well, there are pretty much two measures you need to take. The first is an objective measurement of gear backlash and the second is a subjective "measurement" of the gear mesh pattern using marking compound.
Old Jun 3, 2016 | 02:41 AM
NASSTY's Avatar
NASSTY
I don't know those measurements. My friend did all that, I was just helping him. He's specialized in differential work for over 30 years. He works for cheap for me so I help. He swapped carriers on 2 of my Grand Nationals, my 2011 F150, my 2014 F150 and added a Truetrac and 4.10's in my Bronco.
Old Nov 29, 2016 | 06:08 PM
stein888's Avatar
stein888
2010 f-150 2wd 5.4 litre has 9.75 with 3:15 ring and pinion Would like to change to a 3:55 ring and pinion for towing purposes. Asked dealer and they told me it could not be done they said transmission was synchronized to differential and changing gears would mess things up. I find this hard to believe. Any opionons on if this can be done
Old Nov 30, 2016 | 07:18 AM
Tom's Avatar
Tom
It certainly can be done, your dealer has no idea what they're talking about. Absolutely nothing in the transmission is specific to the differential gearing.
crucialprospect
21
May 13, 2018 04:00 PM
SVTwilliams00
Feb 22, 2016 09:21 PM
78 Ranger
1997 - 2003 F150
Aug 12, 2012 08:59 AM
nomad221
May 29, 2012 01:24 AM
studlybilly
Jul 18, 2004 09:51 AM
