Tps replacement.
Old Jun 1, 2016 | 09:25 PM
wtroger's Avatar
wtroger
Tps replacement.
1992 f-150 5.0. I would gladly like to strangle the engineer that decided to put the Tps on the underside of the TB. Had to take TB off plenum to change it. But it did fix the cold start and idle issues. Also did a 3G upgrade while we where in there.
Old Jun 3, 2016 | 10:04 PM
phnguyk's Avatar
phnguyk
I recently did exactly what you did. However I did the 3G upgrade first, I trimmed the bracket while still in the truck, later I found that the shavings F'd up my TPS. So I replace the TPS, twice! The first AutoZone TPS was crap right out of the box.
Old Jun 3, 2016 | 11:07 PM
Thedonk's Avatar
Thedonk
What were the symptoms u were having? Because my truck all the sudden started to almost die at idle or after i let off the gas and stuff and am unsure why
Old Jun 3, 2016 | 11:22 PM
phnguyk's Avatar
phnguyk
That could be a tps or iac. Mine wouldnt stay running at times without feathering the gas pedal.
Old Jun 3, 2016 | 11:49 PM
Thedonk's Avatar
Thedonk
Is there a way to check those two sensors or do i just replace them and see?
Old Jun 4, 2016 | 08:19 AM
rla2005's Avatar
rla2005
You can measure the TPS with a meter. I prefer voltage versus ohms.
You can also remove the IAC and inspect it for signs of carbon build up. It can be cleaned.
Old Jun 4, 2016 | 11:53 AM
Thedonk's Avatar
Thedonk
I pulled iac off and it seemed really clean actually. How do u test the tps? I can borrow a meter from my dad
Old Jun 4, 2016 | 07:26 PM
wtroger's Avatar
wtroger
His posted a code 63 saying Tps out of range. When we got in there the wires at the Tps didn't have any insulation. Symptoms where a very low idle and hard to keep running cold. Now we get the cold high idle settles down is whole lot better drive ability.
sdawe
Oct 7, 2016 11:55 AM
Anthonynoble
Aug 24, 2016 04:13 PM
bkbkbkbk
Sep 7, 2014 07:08 PM
rickthefix
Apr 1, 2008 01:29 PM
olderguy
Nov 29, 2005 08:11 PM
