1978 - 1996 Big Bronco
tach?
Old Aug 16, 2003 | 12:55 AM
AbadDriver's Avatar
AbadDriver
tach?
my truck didnt come with a tach and i would like to see where my gas is going. my question is could i switch an instrument cluster w/tach for mine without major work, or should i buy an el cheapo aftermarket?
Thx
Tim
Old Aug 16, 2003 | 01:20 AM
oregonian's Avatar
oregonian
tach?
I believe you can because the guy that sold me my '87 pulled my instrument cluster w/tach and swapped it w/his cluster that didn't have a tach. I guess all the hook ups are there, it just depends on which cluster was installed. Not sure of the work involved but it seems like it would be pretty easy. Hope this helps.
Old Aug 16, 2003 | 03:24 AM
88DesertBronco's Avatar
88DesertBronco
tach?
The gas is going down the big 5.8L gullet. And the fact when you step on the gas "it really goes" for a 5,000 pound SUV. I'm lucky to get 10MPG on a good drive. The 3-speed C6 doesn't help though.
Old Aug 16, 2003 | 10:42 AM
steve83's Avatar
steve83
tach?
A tach won't tell you much - install a vacuum gauge. THAT shows where the gas goes. The higher you keep the vacuum, the less gas you're burning.
http://www.superford.org/registry/ve...154&original=1
Old Aug 16, 2003 | 01:31 PM
88DesertBronco
tach?
Great idea. I just went through the whole vacuum tree and with a vacuum pump checked all the parts. The cruise control was leaking, the power brake booster for some weird reason would not hold above 15, so maybe a big leak there, and some interior vacuum control was leaking. D'oh! My vacuum gauge showed about 20 at idle. What does yours read?
Old Aug 16, 2003 | 05:24 PM
steve83's Avatar
steve83
tach?
18-22 is normal - mine was idling when I took that picture, which shows about 21".
Old Aug 16, 2003 | 09:43 PM
AbadDriver's Avatar
AbadDriver
tach?
Originally posted by oregonian
I believe you can because the guy that sold me my '87 pulled my instrument cluster w/tach and swapped it w/his cluster that didn't have a tach. I guess all the hook ups are there, it just depends on which cluster was installed...
thats what i kinda wanted to really know. the vacuum gauge is also a good idea...ill look into tha when(if) i get outa dept with my parents.
Tim
