Differential issues
Seems crazy that this problem just started with a tranny and transfer case replacement, when the issue is really, rear end related.
Maybe the e brake line got pinched or crimped when replacing the tranny?
It's got to be e brake or limited slip differential related. Do you change diff gear oil at the same time?
. Called them up and their going to check it out. I'd check those backing plates before tearing it down. It should be visible once you start poking around back there.
if that's the case, there's a couple tricks pass down to me from Jack (TooManyToys), on holding the parking brake cable to remove it from the bracket on the back of the backing plate.
There's some great people here!!
Also sometimes a stuck caliper will lockup in only one direction due to pad wear, but will allow wheel to move somewhat in other direction
What he said.
Backing plates rust out and holding pins for shoes comes out. Resultin in pins rolling around in drum of rotor and shoes coming loose. Ask me how I know?
Mine kept making a poping noise everytime I made a left turn and could here it if I had the window down. Pins were laying inside drum when I took them off.
I would say to look there like what's been mentioned above. It's a big job. You'll need special socket to take nuts off and you'll end up replacing seals on hub. Get all your parts and tools first. You'll see in my pics my seals were shot. I replaced shoes and pads, 6 cans of brake clean and Ford seals only. Repack bearings. 187K on my rig.
Crawl under truck and check the backing plate with a screwdriver or punch and see if it goes through. Have a good light to check them. Auto Zone had the backing plates in Dorman. 70 bucks for both. Ford wanted 225.00 a side!!!
No more poping noise.
Sounds like a bad case of Me 2.
I need to do mine. I have all the parts now all I need is the ambition.
If you happen to see my ambition please tell it to get home so I can get things done.
Right now I am running right rear with no parking shoes in place do to it
getting stuck and hot going down the road.
xaviar what did you use for packing the bearings when installing them?
Any hints you think are good to share?
I got lucky on the tools. I happened to be at the local pawn store and found
the special socket in there discount bin. $9.00 and it an OTC one.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Now archoil has premium bearing grease i would have used also, but I didn't want to wait 4 more days for it to get to me. I will be ordering a tube of the archoil grease to try out though. I still need to do the front end bearings (nothing wrong with them, just so time for some maintenance up there) so see how well it hold out. I like the write up on it.
So far so good right now. No leaks and she stops and hods her place well.
I would encourage you to not wait on this repair no longer. Your ambition has returned to you as of this writing I feel. You mentioned you have all the parts now. Get her done
Wondering?
