No spark engine cranks
Old May 31, 2016 | 10:47 AM
gimage's Avatar
gimage
Hello,
The truck is a 1995 F150 XL with a 4.9L engine.
I've used this guide, Part 1 -How to Troubleshoot a No Start (Ford 4.9L, 5.0L, 5.8L)., to determine why I'm not getting any spark at either the spark plugs or the coil. I made the LED tester using Radio Shack parts and get a flashing signal, per the instructions, on the ICM (lead #6 and POS on the battery). I get 12v to the coil on one side and the LED tester flashes when the engine is cranking when it is connected to the other side and connected to the POS side of the battery. The original ICM is gray while the replacement is black, if that matters. Thanks for any insight.
Greg
Joel1948
2009 - 2014 F150
Nov 18, 2017 05:57 AM
bruce67
Feb 25, 2017 08:12 AM
exidor12
Sep 13, 2015 06:34 AM
jpjahn
Electrical Systems/Wiring
Jun 6, 2006 08:31 PM
Dave874.9L
Oct 30, 2004 01:29 PM
