1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Auto hubs and defrost control.
Old 05-30-2016, 08:43 PM
Bryanskingranch's Avatar
Bryanskingranch
Bryanskingranch is offline
Hello everyone,
New to this site, and was hoping that some one would know what this unit is called, and or the part number for it. It's my understanding that it controls the auto locking hubs, and the heating/ac ducts via vacuum control. I have a 06 King Ranch 6.0L Diesel. 4x4, F350.
Old 05-31-2016, 12:23 AM
HearseDriver's Avatar
HearseDriver
HearseDriver is offline
It's called a PVH Valve or Pulse Vacuum Hublock Valve. They're about $ 30.00 for a Dorman and around $60.00 for a Motorcraft one. I went cheep and bought the Dorman one and it's working fine. Here's a link to an eBay auction.
Fits Ford 99 10 4WD Differential Switch Dorman 600 402 | eBay
Here's a genuine Ford one on eBay: Ford part# 7c3z-9h465-a
Ford 1999 2010 Ford F 250 F 350 Vacuum Control Solenoid 4x4 Front Hubs | eBay
Before you purchase a PVH valve make sure you CAREFULLY inspect ALL of your vacuum hoses to & from the valve & to the hubs. Especially the rubber ones that run to the hubs. On my V10 I found a section of the poly tubing had melted where it ran down the frame next to the exhaust manifold. I replaced that section with some stainless 1/4" tubing I got from work and bent it to fit with a tubing bender. It will NEVER melt again. I also replaced the rubber hoses with 1/4" drip irrigation tubing - it's UV resistant - I did leave the short rubber hoses from the knuckle to the hub because the poly tubing would kink when turning the wheel lock to lock,
Old 05-31-2016, 09:44 AM
Bryanskingranch
Awesome! Thank you for the help. I spent an hour trying to find that thing on line with no luck, but did find this site! I will take your advise, and go over the lines as you described.
Old 05-31-2016, 06:05 PM
Dormin's Avatar
Dormin
Dormin is offline
Trailering
Trouble also
I have a 2001 F250SD CC V10 doing same thing. Replaced lines from knuckle to hubs. They were super brittle. It got better for a while. AC blows out defrost most of the time. When stopped I can switch to 4H and AC will start blowing out dash vents. Switch out of 4H and accelerate goes back to vents.
Old 05-31-2016, 08:59 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Block off the lines to the PVH solenoid and see if the AC controls behave themselves. If so, the solenoid is leaking.
Old 06-01-2016, 02:53 AM
Thor'sHammer's Avatar
Thor'sHammer
Thor'sHammer is offline
Try this post first (mine, #11).
Old 06-01-2016, 04:44 AM
redford's Avatar
redford
redford is offline
Received 1,581 Likes on 922 Posts
Blowing out the defrost ports means you have a vacuum leak.
Old 06-01-2016, 10:23 AM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
Here is what I did to mine when I had this problem.
Originally Posted by wizkid00104
Thanks Bently!
So I have found my vacuum leak. I stopped after work and got the variety pack of vacuum plugs. In the parking lot I pulled off my hoses for the ESOF and capped them. Nothing changed. Just for fun, I put the truck in 4x4 and my vents started working.... for less than a minute, then quit again. The culprit was the solenoid to engage the front hubs. Apparently they are known for cracking. I suppose mine is also in the boat.
onelionhunter
12-07-2018 03:03 PM
Cryptmaster
06-27-2017 10:23 PM
shield1978
10-12-2013 08:00 AM
2000f250v10
Modular V10 (6.8l)
09-02-2013 09:38 AM
sbowling79
11-07-2012 02:21 PM
Quick Reply: Auto hubs and defrost control.
