1978 - 1996 Big Bronco
mystery buzzer
Old Aug 15, 2003 | 09:41 PM
joebronco94's Avatar
joebronco94
mystery buzzer
When I bought my bronco a few months ago, I had a buzzer going off about every 50 miles or so.Had some work done to it and the buzzer did not do it again. The other day driving down the road it started again, but did it once. Coming home to night it seames to do it every 5 min. Cant figure it out. Thanks in advance.
Old Aug 15, 2003 | 10:38 PM
DW2455's Avatar
DW2455
mystery buzzer
It's POSSESSED!! Get out! Run like hell! Sorry i could not resist. your not hearing the squirle cage on your blower fan making noise are you ? I realy dont have a clue, just a shot in the dark! DW
Old Aug 15, 2003 | 11:17 PM
bigric's Avatar
bigric
mystery buzzer
I'm assuming that this is for a '94 Bronco? What kind of work did you have done that fixed the buzzer problem?
Old Aug 16, 2003 | 07:12 AM
battered_bronco's Avatar
battered_bronco
mystery buzzer
self destruck warning buzzer they probally un plugged it
get ready to jump from the truck
Old Aug 16, 2003 | 10:44 AM
steve83's Avatar
steve83
mystery buzzer
Can you describe the sound or the source? Is it a buzz like an old seat-belt buzzer, or more like a card in bicycle spokes? Is it coming from the L or R side of the dash? Or somewhere else? Next time it happens, slow down and see if the buzz changes with tire or engine speed. Then try changing the fan speed or hitting the dash.
Old Aug 16, 2003 | 03:46 PM
joebronco94
mystery buzzer
Ha, Ha, self destuct did not think about that. No really the buzzing noise is a buzzer device, not a fan or tires. It's 5 buzzing sounds then a pause then 5 more pause. It does this about 4 times then quits for a while. The repairs done to it before where the clock spring and the manual lever position sensor the noise comes from driver side from what i can tell
Old Aug 16, 2003 | 04:55 PM
screwy's Avatar
screwy
mystery buzzer
When you turn the key does the airbag light go on?
Old Aug 16, 2003 | 05:45 PM
steve83's Avatar
steve83
mystery buzzer
Straight off the Ford/Helm service CD:
The supplemental air bag restraint system (SRS) is powered directly from the battery. The supplemental air bag restraint system can function with the ignition switch (11572) in any position, including OFF and LOCK. The supplemental air bag restraint system can also function when the front seat (60012) is unoccupied. The electrical system performs three main functions:
l Detects impacts
l Supplies electric power to the igniter(s)
l Monitors the system to determine system readiness
The electrical system components include:
l Air bag diagnostic monitor (14B056)
l Air bag indicator
l Wiring harness and air bag sliding contact (14A664)
l Sensors:
-- Primary crash sensor and bracket
-- Safing air bag sensor
l The igniter within the driver side air bag module (043B13)
Sensors
WARNING:
VEHICLE SENSOR ORIENTATION IS CRITICAL FOR PROPER SYSTEM OPERATION. IF A VEHICLE EQUIPPED WITH A SUPPLEMENTAL AIR BAG RESTRAINT SYSTEM HAS BEEN INVOLVED IN A CRASH WHERE THE RADIATOR SUPPORT, FRAME RAILS OR COWLS HAVE BEEN DAMAGED, INSPECT THE SENSOR MOUNTING BRACKETS FOR DEFORMATION. IF DAMAGED, THE SENSOR SHOULD BE REPLACED WHETHER OR NOT THE AIR BAG IS DEPLOYED. IN ADDITION, MAKE SURE THE BODY STRUCTURE IN THE AREA OF THE SENSOR MOUNTING IS RESTORED TO ITS ORIGINAL CONDITION.
NOTE:
Undamaged sensors will reset automatically after an accident and can be reused.
The sensors are electrical switches which react to impacts according to direction and force. Sensors discriminate between impacts that require air bag inflation and impacts that do not require air bag inflation. When an impact occurs that requires air bag inflation, the sensor contacts close, completing the electrical circuit necessary for system operation.
Three sensors are mounted in the vehicle. Their locations are as follows:
l A primary crash sensor on the left-hand side of the radiator support.
l A primary crash sensor on the right-hand side of the radiator support.
l A safing sensor at the right B-pillar.
At least two sensors (one primary sensor and one safing sensor) must be closed to inflate the air bag.
The sensors automatically "reset" after a collision and do not need to be replaced unless they are physically damaged. Replace only if proper alignment is not possible due to bent brackets, cut wires, smashed connectors, etc.
Air Bag Indicator
The air bag indicator will light continuously for approximately six seconds whenever the ignition switch is turned from OFF to RUN if the air bag is working properly. If system fault is present, the indicator will either fail to light, remain lit continuously or light in a flashing manner. The flashing manner may not occur until approximately 30 seconds after the ignition switch has been turned from OFF to RUN. This is the time required for the air bag diagnostic monitor to test and verify any and all system faults. If the air bag indicator is inoperative and a system fault exists, a tone will sound signaling that the air bag indicator is inoperative and a system fault exists. Refer to the «Diagnosis and Testing» portion of this section.
Tone Generator
The air bag indicator is the prime means of determining the supplemental air bag restraint system status. However, if the air bag indicator is inoperative and a system fault exists, a tone will sound in a pattern of five sets of five beeps. If this occurs, the air bag indicator will need to be serviced before further diagnosing and testing can be completed. Unless serviced, the supplemental air bag restraint system may not function properly in the event of an accident.
Sounds like the bulb is burnt out. Change it, and you should be able to count the blink code.
Old Aug 16, 2003 | 06:22 PM
bigric's Avatar
bigric
mystery buzzer
I've also read plenty about airbags deploying without warning. Consider that one.
I've never been a big fan of explosions in my face while I'm wrecking a vehicle, but that's just my opinion. I don't think that airbags are going away, however.
Old Aug 16, 2003 | 07:21 PM
joebronco94
mystery buzzer
thanks guys will look into this make since that the clock spring was broke that the air bag will not make contact.
Old Aug 16, 2003 | 07:30 PM
steve83's Avatar
steve83
mystery buzzer
Did you read the bottom of my last post? From "Tone Generator" down.
Old Aug 16, 2003 | 07:34 PM
DW2455's Avatar
DW2455
mystery buzzer
hey steve what those CD's cost and where can i get them? Thnx DW
Old Aug 16, 2003 | 07:40 PM
steve83's Avatar
steve83
mystery buzzer
E-Bay has them, usually for ~$10 delivered. Helm sells them for about 10x that much.
