Dizzy seating question
Old May 27, 2016 | 01:03 PM
tbruz's Avatar
tbruz
Engine rebuild coming along nicely; stabbed a rebuilt dizzy in this morning and have spent 2 hours messing with the seating. I can hit my pre re-build position on the dizzy body and rotor pretty easily buy I cant seem to get it to sit down low enough to get the shaft gasket into the manifold, see pic.(rotor does not spin freely by hand in this position so it feels engaged.
I tried both the original and the rebuilt dizzy and both seem to only drop in the same amount(not enough)
I've convinced my self that I do not have it seated properly.
Also convince myself to walk away before things go worse.
Am I right or wrong??
Any advice appreciated.
Thanks
Tbruz
Old May 27, 2016 | 01:41 PM
HIO Silver's Avatar
HIO Silver
It's not seated all the way... I suggest rotating the crank ever so slightly while applying a slight downward force on the dizzy to get the cam gear and dizzy gear to fully mesh.
See of if that works.. otherwise, it might be an oil pump drive issue.
Old May 28, 2016 | 10:28 AM
flowney's Avatar
flowney
Looks like the front cover might not be sealed up yet. If so, you can peek at the spot where the distributor connects with the oil pump drive shaft. Try HIO's suggestion first, though.
Old May 28, 2016 | 10:31 AM
78 PEB's Avatar
78 PEB
I would bet it hasn't engaged in the oil pump drive. HIO's suggestion should work.
Old May 28, 2016 | 08:52 PM
PA74F250's Avatar
PA74F250
It's the oil pump driveshaft like mentioned. Seems like they lean back in the hole a little and it's nothing but problems. You can trying turning it back and forth it might do it. Now that you walked away for awhile it might drop right in! I had that happen once or twice its always a good feeling but till then.....
Old May 29, 2016 | 05:39 PM
tbruz's Avatar
tbruz
HIO's suggestion worked, I rotated the crank a bit while pushing down on the dizzy and it seated that last 1/4 inch or so.
Should be finishing off my rebuild tomorrow morning and hopefully hit the key for a start around noon........
Thanks to all for their help and guidance.
Tbruz
79-400-POWER
Jun 20, 2007 05:57 PM
Mitchissippi
Mar 27, 2007 10:40 PM
SasquatchF-250
15
May 17, 2005 12:38 PM
FERacing66
General Automotive Discussion
Mar 4, 2004 11:46 AM
siphor84
Nov 12, 2003 08:05 PM
