Rear hub help!
Old May 26, 2016 | 09:36 PM
The_Drew's Avatar
The_Drew
Rear hub help!
Hey guys my bearings are toast in my drivers side rear hub. 10.25 full float.
I have the axle out and the nut off. The outer bearing is clearly busted. Even blown up some of the roller bearings in it.
I cannot for the life of me get the hub off.
Here's what I tried:
A puller that I had(now broken)
Putting the tire on and beating on it
I made a steel bar that bolted to the hub and tried to slide hammer it off as well as beating the f out of it with a bfh
How the heck do I get it off? I did all the things the book said.
Also: at this point I'm sure my spindle is crapified. Should I just get another axle? I know the spindle isn't replaceable. I have a lead on an axle with the same gears and limited slip for $200
Direction?
Thanks guys
Old May 27, 2016 | 11:21 AM
Phy's Avatar
Phy
If the spindle is now bad, then get the other axle, no question.
Old May 27, 2016 | 12:07 PM
Diesel_Brad's Avatar
Diesel_Brad
Are you out of gear oil?
Seems weird that the bearing welded itself to the spindle
Old May 27, 2016 | 12:43 PM
4DB's Avatar
4DB
I know that when I did mine that the rear seal clung to the spindle in a fashion I would never have imagined. If it hadn't finally come apart I never would have believed it could be the seal causing the problem. These 10.25 axles use a seal that rotates within itself. What actually sits on the spindle does not turn and glues itself to the spindle over time.
Fortunately my axle puller did not break, but I was getting worried!
Old May 27, 2016 | 12:50 PM
The_Drew's Avatar
The_Drew
There was gear oil but I think it was low.
Old May 27, 2016 | 01:02 PM
Diesel_Brad
LOL< looks like scrap to me along with the rust in the hub,
Replace the axle
Old May 27, 2016 | 01:13 PM
GuitarJesus's Avatar
GuitarJesus
Looks dryer than the Mojave in August. Replace that crap.
Old May 27, 2016 | 02:11 PM
The_Drew's Avatar
The_Drew
Lol, thanks guys. Picking up the other axle Tuesday night. A little upgrade to limited slip too
Old May 28, 2016 | 04:50 PM
The_Drew's Avatar
The_Drew
Here's my little rig I made to try and whack/slide hammer the hub off
davlun
25
Aug 17, 2014 03:00 AM
jollygreen_giant
15
Dec 8, 2010 12:38 PM
cookie88
22
Aug 11, 2009 05:52 PM
toyota1988
Oct 8, 2003 10:39 AM
bkeese
Jan 2, 2003 09:06 AM
