93 f-250 Overdrive
on
Is this just driving around unloaded or when hauling a load? If there are no codes present(that is a hint.. check for codes) then it is probably just that your friend is driving right at that speed where the vehicle can't maintain speed in OD so it should be locked out.
if there are no codes from the trans,then suspect a worn tps.info:
https://www.ford-trucks.com/forums/1...ions-only.html
rick,also have your friend pay attention to the tach and speedo readings.if he sees any fluctuations in either of those,that would be the source of his trouble as well if it's not yet bad enough to toss a code.
Al Tamm
10-11-2013 09:15 AM
jtyson8602
24
09-24-2013 12:09 PM
TulloFord
03-06-2012 10:30 PM
