Sponsored by: Real Truck
Speedo is wrong....changes to make?
Old May 25, 2016 | 04:50 PM
DieselCamper's Avatar
DieselCamper
Hey guys, so my 08 F250 is running 37 inch tires which is obviously bigger than stock, and I haven't gotten the money to buy a tuner to fix it. My speedo is wrong which also means my mileage counter is somewhat wrong, so what changes do I have to make to my mile intervals? Do I change the oil at 2500 miles instead of 3000?
Old May 25, 2016 | 07:51 PM
Just Strokin's Avatar
Just Strokin
Do a 5 mile speedometer check. See how far off you are in the 5 miles and then scale it up 3000 miles to see how far off you are. Personally, I think it isn't an issue to worry over and just change oil when it hits say 5,000 miles.
If you really want to correct it, you might try to see if the dealer can change the tire size with the Ford IDS.
Old May 25, 2016 | 08:00 PM
DieselCamper
Okie dokie! Thanks!
Old May 26, 2016 | 12:40 AM
jlmotox's Avatar
jlmotox
Dealer said they could only adjust for up to 35" tires on my 05' with 37's
I bought a SCT X4 that I thought would fix the the speedo but that only fixed the shifting of the trans...
Bought a hyper tech speedo calibration unit that plugged into the back of the speedo for $200 that fixed it finally. Not sure if the 05'-08' are the same but that's what I ended up doing...
jonmorgan
Modular V10 (6.8l)
Jul 18, 2015 06:31 AM
Djphelan01
Apr 12, 2013 07:07 PM
sambandit03
Mar 18, 2010 10:09 PM
BatteriesNotINCL
2004 - 2008 F150
Apr 4, 2009 12:51 PM
92E150
Jan 19, 2008 07:10 AM
