Yep...another build thread
Old Jun 1, 2016 | 01:46 PM
mike1202002's Avatar
mike1202002
Originally Posted by twofifty
Your project has caught my eye. I have a couple questions for you on the 2wd plastic tank. Could you post a couple more photos of that setup you are running? I'm curious if the 2wd plastic side tank mounts the same as the 2wd metal tank.
Also, did you get your brake proportioning valve aftermarket, or are you using the original just cleaned up?
I'll be keeping an eye on whether you'll need to swap your steering column as well as I was told the 2wd is different... would love to see yours hook right up!
Great project and good luck!
I can definitely get some pictures for you. It might be this weekend though as the truck is at my parents shop. It essentially mounts the same way there were two pieces we didn't use to mount the tank. A side shield and a support bracket. I might eventually try to put a loop on the rear driveshaft just incase. I am going to put new u joints in it but you never know.
The proportioning valve is from BGY I am going to rear discs on the back and I have a Hydroboost unit from a mustang I am going to see if it fits. If it does I am going to go Hydroboost also.
I have heard the same thing I was just going to swap columns. Plus my 2wd was an auto but I could compare them for you when I swap mine.
Planning on doing brakes, getting ready for a cam swap and getting the fuel system lined out this weekend.
Old Jun 5, 2016 | 07:02 PM
mike1202002
Hope these help some what. In the first pic you can see the bracket I have to cut and drill since we moved the tank back. Also the last picture shows how the transmission is sitting right now so the should give us more room between the yoke and the tank on the transfer case as. Since there's about an inch maybe a little less between the two currently. Also should gain some more room between the tank and transmission when the engine is put in since they are back all the way.
Old Jun 5, 2016 | 07:07 PM
mike1202002
Not a lot of progress made these weekend but there was some sending units are in, fuel lines in, brake lines tightened down except for the master cylinder lines. Also done away the drum brakes and started the rear disc conversion.
Duratracs will be here Tuesday, went with 285/75/16.
Old Jul 9, 2016 | 02:53 PM
mike1202002
Some updated pictures.
brentadams646
Dec 6, 2023 04:46 PM
F100wish
Jun 18, 2019 08:12 PM
F150Dan
103
Jul 20, 2014 02:14 PM
69f250Dually
Apr 13, 2013 10:06 PM
boggin79ford
Vehicles for Sale
Mar 28, 2012 06:04 PM
