I just started having an issue on my 01 7.3 f350 with 203k miles, it will crank much longer then normal to start. If you shut it off then try to restart right away it starts normal, if you wait 10 minutes long crank again. if you shut it off and turn key back on but don't start it you can wait an hour then start right away. IDM bad?
Vacation in 2 weeks and I would like to get this fixed first.
If you had oil penetrate the plug, I would replace the pigtail as well. Inexpensive and helps eliminate the worries. Dieselorings.com is a site supporter and has them, I ordered from him and received them quickly with good communication.
If you restart right away it starts fine, if you shut it off and turn key back on but don't start it can sit for a half hour or more and will start right up like normal. Let it sit ten minutes with key off long start.
