What did I do wrong?
Old May 21, 2016 | 02:18 PM
inspector1's Avatar
inspector1
While doing my weekly check out of my truck (2000, DRW, 6 Speed - Hand Shaker with 344,420 miles) I noticed that I was about 2 quarts low on oil.
So I started at the top (of the motor that is) and looked for leaks. None at any of the usually suspected areas.
Finally found the leak after a thorough cleaning, was the HPOP at the rear plate.
I made the call to go ahead and replace the HPOP along with a re-ring of the fuel bowl.
Thanks here to Riff-Raff for the fair price, quick shipping and for the stickers.
Changed out the HPOP and put everything back together.
After the first attempt at cranking, I noticed that the driver side hose had come loose from the head. Here is a tip, check that the split ring is still in the fitting LOL.
This is where I get confused, I had read that after this process I should expect a very hard start condition.
My truck started with only 3 attempts, there was no rough idle and I just drove to Texas from Alabama with no ill affects.
Guess I got lucky
On a serious note, I now have the 'Water in Fuel' light on my dash. I know for a fact that there is NO water in the fuel bowl. What could I have done to cause this and how should I go about correcting?
Thanks in advance for reading this wall of text, and for any help.
Old May 21, 2016 | 02:51 PM
jhl3's Avatar
jhl3
Good job on the HPOP. That is about the standard crank time post HPOP install if you fill the reservoir.
Do you have any way to clear codes: ForScan, AE? and then see if it still exists. Have you checked the connection on the back of the fuel bowl? Inside the fuel bowl?
Old May 21, 2016 | 03:02 PM
inspector1's Avatar
inspector1
I only have scan-gage at this time. It tells me that I can clear codes, to be honest, I had not thought of that.
Old May 21, 2016 | 03:04 PM
inspector1's Avatar
inspector1
all connections are good and tight, I cleaned with air prior to reinstall.
Old May 21, 2016 | 03:06 PM
inspector1's Avatar
inspector1
Also, Water in Fuel light is not steady (should have included this in OP), it comes and goes - seems to go away under acceleration, but not all of the time
Old May 21, 2016 | 03:12 PM
Don Naslund's Avatar
Don Naslund
The water sensor sometimes gets corroded and needs to be replaced.
Old May 21, 2016 | 03:25 PM
inspector1's Avatar
inspector1
Don,
this is where, and how to replace?
thanks in advance
Old May 21, 2016 | 03:26 PM
inspector1's Avatar
inspector1
there was a lot of junk in the fuel bowl, under the heater.
washed out and noticed nothing that needed further inspection,
thanks again
Old May 21, 2016 | 03:29 PM
inspector1's Avatar
inspector1
no doubt most of that trash was there prior to the hutch and harpoon and not noticed during subsequent filter changes
Old May 21, 2016 | 03:46 PM
jhl3's Avatar
jhl3
Everything you will need to know courtesy of Guzzle: Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
Old May 21, 2016 | 03:57 PM
inspector1's Avatar
inspector1
Thanks for the link,
I followed the instructions during the rebuild, that is where i am lost.
Thanks again
Old May 21, 2016 | 03:59 PM
inspector1's Avatar
inspector1
I will use scan-gage to clear codes then I will just run it and see what comes up.
Thanks again
Old May 21, 2016 | 05:10 PM
jhl3's Avatar
jhl3
If resetting and cleaning don't work; I've never had to replace one but here is a link to the replacement:
Fuel Bowl Thermostat/Water-in-fuel sensor Electrical connector 1999-2003 F-E series 7.3L diesels
Very similar instructions:
http://www.dieselorings.com/docs/FuelBowlRebuild.pdf
Old May 21, 2016 | 05:16 PM
inspector1's Avatar
inspector1
jhl3
thanks, will look into that
Old May 23, 2016 | 01:00 PM
Don Naslund
You also can go to youtube and check for videos on water in fuel sensor for your vehicle.
