What Is It?
Old May 21, 2016 | 11:15 AM
john jamieson's Avatar
john jamieson
What Is It?
In repairing my ac I broke a 1/16 vac line going to this thing. The symptoms were I only had air flow to the defrost and my auto transmission was slipping so that I couldn't go over 30mph. The line is repaired and everything seams to be working correctly. So What Is it?
Thanks.
john
Old May 21, 2016 | 01:30 PM
glockholiday's Avatar
glockholiday
Your vacuum reservoir tank. It makes sure there's always enough vacuum supply to operate the vacuum operated accessories on your truck.
Old May 21, 2016 | 02:39 PM
pawpaw's Avatar
pawpaw
Don't know how many miles you drove with the tranny slipping, but I'd sure do a poor mans tranny fluid oil analysis, or maybe consider changing the fluid & filter to be safe, as a slipping tranny will over heat the fluid & clutch pack, not a good happening for longevity.
Old May 21, 2016 | 03:03 PM
Don Naslund's Avatar
Don Naslund
I would guess that the trans wasn't slipping, it was simply not shifting.
Old May 21, 2016 | 05:30 PM
john jamieson
Thanks for the inputs. The tranny wasn't shifting and I only drove about a mile with it acting up. My tranny was serviced a couple months ago and hadn't acted up until I did the ac. It's all good for now.
Old May 21, 2016 | 07:14 PM
pawpaw's Avatar
pawpaw
Well sounds like you probably didn't do much, if any fluid or clutch pack damage if you took it easy for that mile.
5X5
Apr 16, 2012 07:06 PM
WF1982
Sep 10, 2009 09:00 AM
geraldweber
Jan 15, 2007 04:08 PM
rbastedo
Aerostar
22
Nov 10, 2004 11:53 AM
Sheemie
May 25, 2004 01:01 PM
