Very Slow Acceleration
Old May 21, 2016 | 05:01 PM
BrittsNFords's Avatar
BrittsNFords
Originally Posted by orich
1. What's the voltage going to your coil while it's running?
2. Also where do you have your choke power wire hooked into for power?
3. when was the last time you check the compression or spark plug color for a lean
or rich condition?
Also is that a 428 engine or the 76 truck intake manifold.
Orich
The voltage to the coil while running is about 14V.
The choke wire goes through the firewall and to a flat terminal connector on the fuse box. Measured at 12V while running.
I haven't checked compression a long time. The plugs are new but I'll check the compression out when I get the chance.
How can you tells its a 428 intake? That's news to me. Is that going to have undesired effects on performance?
Old May 21, 2016 | 05:05 PM
mountain dewd's Avatar
mountain dewd
Do you have a 12V coil?
Old May 21, 2016 | 05:06 PM
BrittsNFords
I opened the op of the carb while tinkering and, lo and behold, the fuel bowls had a bunch of crap in them. I gave them a good cleaning. I talked to my neighbor who is mechanic and he would swap the front and rear jets on this carb with a 360. So I did. He then helped me set timing and re adjust the carb screws. Works much better now, but still not quite perfect.
I'm not sure if the jet swapping helped but I'm sure it helped to clean out the jets. The accelerator pump looked springy and the seal wasn't hard so I haven't ordered a replacement yet. But with all that dirt I found I'm tempted to pull it and give it a full cleaning. But for now I'm just excited to be driving again.
Thanks everyone for your help
Old May 21, 2016 | 05:09 PM
BrittsNFords
I'm not sure, I'm guessing it is. It's a standard replacement coil from napa, not a high performance one.
Old May 21, 2016 | 05:33 PM
orich's Avatar
orich
Intake if 428 has casted numbers on #1 port runner these numbers in front of carb
C8OE-9425-A cast iron intake..
orich
Old May 21, 2016 | 06:07 PM
BrittsNFords
Ah I see. I'm still a bit of a noob. There is a big S, then C7AE-9425-E. From my googling, it must be a '67. Thanks for the info. I'm learning a ton about these trucks on this forum
Old May 22, 2016 | 01:22 AM
GaryKip's Avatar
GaryKip
Replace the fuel filter yet? Yours may be on the bottom of the fuel pump.
Old May 22, 2016 | 09:42 AM
BrittsNFords
I did replace the fuel filter, it's between pump and carb. Since there's a bunch of sediment in the carb, maybe I'll pull the pump and see if its gunked up as well.
Old May 22, 2016 | 06:50 PM
orich's Avatar
orich
Yea but crap coming from what's in tank or going into the tank. May be clean the tank out.
Orich
D-rat
81
Jan 9, 2017 12:23 PM
lvin4jc
Sep 19, 2014 03:25 PM
Citizenrain
17
Jun 11, 2012 02:30 PM
Racerdave
Jan 20, 2011 05:03 PM
Racerdave
Apr 16, 2003 02:51 AM
