Sponsored by: Real Truck
sync help
Old May 23, 2016 | 04:09 PM
  #31
1turbo6's Avatar
1turbo6
Originally Posted by rvpuller
The $150 is for a map update not the sync software update, the software update should be free.
Denny
No nav. It was for Software but couldn't do it since module appears to be dead
Old May 23, 2016 | 05:11 PM
  #32
Crispy71's Avatar
Crispy71
If the aipm is dead, talk to Circuitboard Medics (one of the forum sponsors) and see if it something they can repair? I know they do instrument clusters and pcms.
Old May 24, 2016 | 06:33 AM
  #33
redford's Avatar
redford
FTE Leadership Emeritus
@CircuitBoardMedics
Can you help?
Old May 24, 2016 | 10:11 AM
  #34
1turbo6's Avatar
1turbo6
ok module appears to be dead and ford told me to pound sand... I found the module in the truck but cant get to the bolts easily anybody remove one of these?
Old May 24, 2016 | 10:38 AM
  #35
Firekite's Avatar
Firekite
I have never tried to take one out, but if it's likely someone jacked up the module trying to hook up an aftermarket system or whatever, then I'm not surprised it wouldn't be covered under any warranty.
Old May 24, 2016 | 10:51 AM
  #36
1turbo6's Avatar
1turbo6
Can't say for sure if it had a system or not, no evidence of one.
Old May 24, 2016 | 11:32 AM
  #37
Firekite's Avatar
Firekite
Well then unless you have a bumper to bumper ESP that covers it, if you're out of the warranty period it is what it is.
Old May 25, 2016 | 09:33 AM
  #38
CircuitBoardMedics's Avatar
CircuitBoardMedics
Thanks for tagging us to help with this Redford.
1turbo6, can you pull and check fuses 83 (20A) and fuse 29 (20A)? Please physically pull the fuses out and confirm continuity.
If the APIM is faulty, I'd love to have a look at it, but there are a lot of things about this one that create cause for concern that something else could also be contributing to the problem.
Old May 25, 2016 | 09:48 AM
  #39
1turbo6's Avatar
1turbo6
I pulled the fuses and they have continuity. Any other ideas? Thanks in advance
Old May 25, 2016 | 10:32 AM
  #40
CircuitBoardMedics
OK, let's focus on the 12V cigarette lighter not having power first since it is the simpler circuit. Since fuse 83 is good, let's see if it has +12V on that circuit. Can you check directly from the contacts on the back of the fuse to ground to see if there is +12V there?
Old May 25, 2016 | 10:44 AM
  #41
1turbo6's Avatar
1turbo6
I did get the cigarette outlet working the other day it was fuse 83 as u stated.
Old May 25, 2016 | 12:24 PM
  #42
CircuitBoardMedics
I missed that. I'm sorry!
Well, I was hoping that we were chasing a bad ground. I'm assuming that the USB port still isn't powered though. Can you confirm that it still will not charge your phone?
Old May 25, 2016 | 12:32 PM
  #43
1turbo6's Avatar
1turbo6
Just double checked, it still does not charge phone. Is the usb powere by the Apim module?
Old May 25, 2016 | 12:36 PM
  #44
CircuitBoardMedics
Just double checked, it still does not charge phone. Is the usb powered by the Apim module?
Yes, it is. I you're able to get the APIM out, give us a call at 800-547-2049 and we will bring it in for an evaluation.
Old Jun 2, 2016 | 03:34 PM
  #45
1turbo6's Avatar
1turbo6
Got it out, also Called and left a message. Strange that it has a different p/n on each side. Is this 2 modules in one?
