400 build
Old May 18, 2016 | 11:17 AM
Slough172's Avatar
Slough172
400 build
I've had my 78 f150 with a stock 351m for 8 years now and recently decided to make it my hunting truck. The 351 did fine as a farm truck but it leaks oil and just won't cut it for moderate road trips and some of the off-road conditions. I already plan to do a 400 conversion but want to do a mild build. I've done some motor work but never torn one down this much and could use some advice. I plan on getting higher compression pistons(I know I need new ones anyway for 400 crank so might as well go aftermarket), comp xtreme energy cam kit (with double roller timing chain), msd distributor, shorty headers, and true duals. I am open to all suggestions and any information. Please let me know any thoughts yall have or any other things that I may need to keep in mind as I do this or address while I'm in there. Been reading on this forum for many years and have learned a whole lot thanks to everybody on here.
Old May 18, 2016 | 11:27 AM
mjr46's Avatar
mjr46
contact t-meyer for your 400 conversion....I did and got all from him, I couldn't be happier with the results
Old May 18, 2016 | 09:27 PM
mark a.'s Avatar
mark a.
Make sure the align bore is good in the block and make sure rods bores are ok. Set your bearing clearances with a dial bore gage reading in .0001"
79blakemaggard
17
May 1, 2015 11:43 AM
peakster
Nov 5, 2014 07:22 AM
GOVTMOD
Apr 24, 2012 12:33 PM
BDawg171
Nov 3, 2010 05:27 PM
blueonblack
1978 - 1996 Big Bronco
Mar 1, 2010 11:26 PM
