Dana 60 swap
Cost breakdown as of 5/21/2016
Parts
Dana 60 takeoff axle (Hollander parts): $425.00
Liftgate service for axle (I was out of town for work and didn't want the wife to have to mess with going to the terminal to pick it up) $150.00
Powerstop AR8580XPR drilled and slotted rotors (Amazon) $119.25
Powerstop S4709 calipers and brackets (Amazon) $185.97
Hawk HB302Y700 LTS pads (Amazon) $78.84
Russel 696490 stainless brake lines (Amazon) $158.40
New Timken 515020 unit bearings (Amazon) $365.56
New dorman 917-513 unit bearing studs (Amazon) $47.50
New moog k80026 upper ball joints (Amazon) $47.90
New moog k8607T lower ball joints (Amazon) $88.50
New moog es3427T tie rod end (Amazon) $36.78
New moog DS1439 tie rod end (Amazon) $97.78
New moog ES3423 tie rod end (Amazon) $45.00
New moog ES3422S steering center link (Amazon) $18.88
New moog DS1438 tie rod end (Amazon) $80.78
New moog ES3426S steering center link (Amazon) $16.99
New spicer SPL55-3X u joints (Amazon) $96.58
New motorcraft auto locking hubs (Dieselorings) $508.44
New hub orings (Dieselorings) $10.38
New motorcraft F81Z-3B458-AA thrust washer sets (Dieselorings) $46.68
New motorcraft F81Z-4428-BA vacuum washer (Dieselorings) $12.38
New yellow hub orings (Dieselorings) $6.50
New motorcraft 3C3Z-3254-CA axle shaft seals (Dieselorings) $127.66
New motorcraft axle dust seals (Dieselorings) $46.38
Total: 2811.63
Also what I see.... unit bearings, ball joints, hubs, u- joints, diff cover all the same.
also check all the wheel studs, they will or can bend or snap in a roll over. I'd consider a unit bearing suspect if any wheel studs are bent.
