Max tire size
this guy is running 38x15.5r20s Nitto Trail Grapplers on a 8" lift
SGT MAC The 01 F250 build thread - Ford Powerstroke Diesel Forum
I have always been successful putting tires on vehicles that nobody said would fit just because I got out there and did a lot of measuring. Jack the vehicle up and turn the wheel lock to lock and measure off your existing tire/wheel combo. If you are just changing tires it should be easy to grab a straight edge and look for potential contact points. That's what I did to make sure 37's fit on my truck and I have had no issues. I'm currently doing the same thing for my Mustang...trying to fit some 335/30/18's under the back of a fox body convertible.
Yeah. I would jack under the leaf spring pads on the axle and support with a jack stand just in case. Just make sure you leave enough room to turn the wheel lock to lock.
They do make a tool to do this, but I am too cheap to buy one when I can do the same thing with a straight edge and measuring tape.
http://www.jegs.com/i/Percy's/760/01...FQetaQodcZAJzA
But yeah, if for some you're looking to go wider (to each their own
) with your current wheel/spacer setup, then start at the rear while it's resting on the ground and measure how much clearance you currently have between the inside of the tire and whatever it's nearest to contacting. Then go to the front, turning the wheel to full lock one way, measure clearance, then the other way, and measure clearance. I'm not sure if there's any advantage to jacking it up, but if you make sure both sides are on jack stands at the same time I guess you avoid making black marks in your driveway (or just do it on the street or in a parking lot nearby or whatever). It would help to have a friend hold the steering wheel against the lock.If you really wanted to get into it, you would need to do it while cycling the suspension. Get one corner lifted as high as it can get to max out travel (to the bumpstops preferably, assuming they've been extended to account for the lift) and see what if anything the rear tires are getting close to and the same for the front at each opposite lock. This also assumes you never air down for off roading such as for sand and such.
Regardless, once you're done, you know that if you have maybe an inch of clearance at the extremes then maybe you can get away with another inch wider tire (half an inch outboard and half an inch inboard) and still have a little clearance, but you're pushing it. Or if you have 6" of clearance then knock yourself out with wide tires
what kind of mpg are you getting right now? I was getting 11 hwy with 4.30 gears and 35's(34.8").
I went down to a 33" tire without much change so I did the freespin hubs, electric cooling fans and a sct tuner. I'm now getting 13.8mpg.
I was getting 14.4 but I installed a bbk throttle body and it went down a little. I've been thinking of going up to a 37" toyo mt but I'm not sure I want to loose that much mpg and might just go with their 315/70/18 (35.7)" tire instead
you'll definitely need a re-gear for 37's. you can free up some mpg with some headers and a free spin kit.
the free spin kit freed up the most mpg for me but the kit is in the 2200 price range plus installation.
I'm in the process of finishing up a installation of a set of banks headers. I'm hoping to see a little more mpg increase with them
