Couple questions...
I use it for the farm in the summer, pulling a tandem axle goose and delivering fuel to the field and I haul my truck camper up north to my hunting spot as well.
Anyway, I've modded it somewhat. I did an the spring shackle swap in the front years ago and installed roller bearings in the pivots, all Super U's in the driveline, B&M deep sump pan on a Ford SVO built E4OD (my BIL is an engineer at Fords and at the time worked in SVO so they did the trans for me). It has a Banks trans command module and a huge Hayden trans cooler that SVO put on. Straight exhaust all the way back. Riff Raff boots and hoses. and Firestone air bags out back I have an ARB in the front and a Tru-trak in the back.
The usual maintrenance, 5K oil changes and a K&N cold air intake and a mild Banks chip. A couple crank position sensors along the way, nothing major, just normal stuff. Did the front end about 3 years into it's life with real Moog joints, not the OEM plastic crap. Everything is greaseable, even the PITA uppers.
It's 5 over stock, just about too high for my wife to climb into
No big tires either. I'm an old fart.I'm curious about whether I can clean the engine compartment and engine (covering the intake and removing the K&N of course.) and would it be advisable to delete the stock pedestal. The EBP or whatever it's called is leaking a bit and I hate oil drips.
I pulled the crankcase vent crap off years ago and ran a hose from the breather box, over the power brake can, down the inner fender and back on the frame, but I've been thinking of adding a catch can and reinstalling the breather into the turbo inlet pipe.
Need some opinions and no, it's not for sale but I will post some pictures someday, if I can figure out how the new digital camera works I got for Christmas and figure out how to upload them on here....
My rear tank float got wonky (front tank is fine) so I fill it up and go 250 miles and switch tanks. Empty I get around 21 (last time I checked which was 10 years ago).
Cannot afford a new one and I don't want DEF crap anyway. You won't find any Tier 4 final tractors on my farm....or vehicles.
Need some constructive input please....
I use to psi wash my engine comp on a regular basis, covering critical areas of course with no problems.. I dunno if at this point I'd advise it or not. On my current 96 I wipe everything down by hand frequently to keep it looking good so it doesnt get outta hand.
I have a nice drive over pit at the shop to get underneath them.
How often do you recoat?... and, do you thin it before spraying and if you do, with what?
