F350DRW vs. F450DRW (gas or diesel)
I have to say, I had my mind all made up on my new 17 SD order but after spending about an hour on this forum, now I'm questioning my direction. Maybe some of your veterans of pulling/hauling can point me in a better direction.
I going to be using my SD to pull an INTERSTATE 12 TON GOOSENECK TRAILER TILT & STATIONARY DECK and haul heavy equipment (specs below):
Model:G24TDT
Load Capacity: 24,000 lbs. at 55 mph. (G.V.W.R. 30,600 lbs.)
Overall Length: 38 feet 1 inch
Deck Length: 28 feet (24 foot tilt deck + 4 foot stationary deck)
Deck Width: 8 foot 6 inches
Deck Height: 36 inched unloaded
I thought Diesel was a no-brainer, but many on this forum are saying gas is the way to go?
Also, F350DRW or F450DRW? As you know, the diesel motor is like 8 grand. Should I get a F450DRW in gas?
Model:G24TDT
Model:G24TDT
Model:G24TDT
F-450
F-350
I just re-read your trailer's weight. Is the 30k you listed the combo rating or just trailer? I'm assuming since you said the trailer was a 12 ton it's combo. If so, the 350 could handle that.
The total weight (trailer and load) is 30,600. The load max is 24,000 and the trailer weighs 6,600.
Yeah, my dealer said the F350DRW will do it, but if I ever push it I'm thinking the F450 would be better and I agree Fidel, it looks cool, which 50% of a truck for for function and the other 50% is for the chicks
Hi Karl,
I'm thinking 450 too. I just talked to my guy at the Ford store and he said the the problem he is having with the 450s are build times. He said he waited almost 8 months on a 2016 450 build.
So the strategy is going to submit a new 17 450 build and if he doesn't get a confirm build date in a couple of weeks, we'll drop down to the 350.
I guess the 450s are not very common builds?
