Sponsored by: Real Truck
Back-up sensor power supply?
Old May 14, 2016 | 05:54 PM
madjak's Avatar
madjak
Installing back-up sensors on my 2003 Ford F250. Everything is done except attaching wire to 12V power source. Was thinking of using back up light for power source but not sure which wire it is. Have not removed taillight assembly yet so it might be obvious once I do this. Just wondering if anyone knew the exact wire?
Thanks,
Old May 17, 2016 | 10:12 AM
f250mtnbikr's Avatar
f250mtnbikr
madjak,
I have 2002 schematics. If it is the same as your 2003, then it shows a BK/PK wire to turn on the backup lamps.
I am thinking that would be a black wire with a pink stripe.
Good luck, Tom
Old May 17, 2016 | 10:59 AM
madjak's Avatar
madjak
Thank you Tom...I pulled the reverse bulb from the taillight and it is just as you said...black with a thin pink stripe. Tied into this one and my back up sensors came to life.
ChiefGeek
Aug 11, 2017 10:11 AM
jgilrfr
Jul 23, 2017 10:25 AM
JD Q
2004 - 2008 F150
16
May 19, 2017 09:56 AM
oceantrav
Jan 11, 2017 04:43 PM
HARALSON COUNTY
1997 - 2003 F150
May 16, 2015 07:49 AM
