1984 F100
Old May 12, 2016 | 08:26 PM
i4got68's Avatar
i4got68
1984 F100
Hey everyone,
I'm looking to buy an 84 F100 with the straight 6 short box step side 2wd. The guy says it hasn't ran in 3 years. I don't know much about the 80s series of Ford so I was curious if '84 still had full on carb with the mechanical fuel pump or if it was that weird electronic ignition carb setup. Also, what would be some things I would need to look at before buying? And another thing, what do you think could be potentially easy fix?
Thanks in advanced everyone!
Old May 12, 2016 | 08:30 PM
Franklin2's Avatar
Franklin2
It has the weird computerized carb setup. Down underneath there is still a good old 300 six, so it can be converted if needed to a older regular carb and dist.
Old May 12, 2016 | 08:31 PM
bruno2's Avatar
bruno2
I dont think the F100 ran past 1982. In 1983 Ford debuted the little Ranger and it replaced the F100. I could be wrong.
Old May 12, 2016 | 08:34 PM
i4got68's Avatar
i4got68
Alright, thanks for that info. Whoops, looked closer at the pictures and saw the F150 logo. That's still good to me though. Now, when I go look at the truck, what are some things that I should be looking at? And also, what could be the potential issue in the truck not running?
Old May 12, 2016 | 08:36 PM
i4got68's Avatar
i4got68
Here are some pictures of the truck
Old May 13, 2016 | 05:59 AM
FuzzFace2's Avatar
FuzzFace2
The truck looks in pretty good shape.
From under the truck check the floors rockers and cab corners for rust.
Like any used car or truck ck fluids for color and smell. Motor oil & radiator trany if auto.
Rest is hard as it doesn't run or drive.
Dave - - - -
Old May 13, 2016 | 07:11 AM
Franklin2's Avatar
Franklin2
If there are lots of lines disconnected and plugged on or around the engine, expect to have to deal with all that.
Old May 13, 2016 | 07:20 AM
DeereFord300's Avatar
DeereFord300
Just for reference that would be an 80 or 81 because of the grille
billabongboy73's Avatar
billabongboy73
Good looking flareside, but that front end is saying it's an 80 or 81.
Old May 13, 2016 | 07:22 AM
bruno2's Avatar
bruno2
I was going to say the letters on the hood were 80-81. 1982 was the first year the letters came off of the hood and the blue oval appeared in the grill.
Old May 13, 2016 | 10:25 AM
Dorsai's Avatar
Dorsai
I believe the amber lights in the front mark it as an '81...if I remember correctly the changeover from the white lenses occurred midway through the 1981 model year.
It's possible it has had a full front clip replacement; the style of lettering on the front fender emblems marks it as earlier than 1984 as well. I'd run the VIN through a decoder to verify the year before purchasing.
Old May 13, 2016 | 12:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I don't think the F100 ran past 1982.
1983 was the last year for the F100. Ranger introduced in March 1982 as a 1983 model.
Old May 13, 2016 | 12:44 PM
Rusty_S's Avatar
Rusty_S
Yep and from the photo showing the fender side it looks like it has the small 80-81 F100/F150 style emblem vs the large lettered 82 and up F100/F150 emblem.
Think this is a 80-81 vs a post 82.
Old May 13, 2016 | 12:45 PM
DeereFord300
Assuming the front end is original it's an 81
Old May 13, 2016 | 01:16 PM
NumberDummy
1982 was the first year for the Blue Oval grille emblem. When this occurred, Ford obsoleted the 1980/81 grilles, replaced them with 1982 grilles.
