Need info on a knuckle
Old May 12, 2016 | 08:26 AM
Hound Dog Lew's Avatar
Hound Dog Lew
I need to replace my left knuckle. Can someone tell me what years will fit? Or do I need to provide more info?
1983 F150 RWD
Old May 12, 2016 | 01:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1983 F150 2WD
Are you asking for the left spindle (3106 in pic)?
Old May 12, 2016 | 03:58 PM
Hound Dog Lew
Yes sir I am. Please forgive me if I have used the incorrect term. I've seen knuckle, spindle, they're the same thing, the spindle connects to the knuckle.
I'm confused.
But yes, 3106, the part the ball joints are pressed into!
Old May 12, 2016 | 04:21 PM
FuzzFace2's Avatar
FuzzFace2
That picture is showing a kingpin type spindle.
Now what I have found with my 81 trucks is there are 2 different spindles.
1 Spindle is for the small wheel bolt pattern and the other for the big wheel bolt pattern.
There is also 2 different kingpin sizes listed based on power or non-power brakes.
I have not confirmed this yet but have confirmed the 2 different spindles based on wheel size as I tried to swap brake parts (rotors) between the 2 and found thay do not interchange.
Again this is for 1981 F100/F150 with kingpins so may not be an issue with your 1983 truck using ball joints.
Dave ----
Old May 12, 2016 | 04:46 PM
NumberDummy
OP has a 1983 F150 2WD
EOTZ-3106-L .. Left Spindle / Obsolete
Last MSRP: $242.68 / Dealer net cost: $145.61.
F100 with front axle parts lists 30.1E / F150 with parts lists 30.1E & 30.1J
F100 applications: Look at the parts catalog pic for 30.1E .. I'm not gonna type all these applications.
F150 applications: 1981/83 F150 2WD with stamped axle from 8/81 to 6/83 / 1983 F150 2WD from 6/83 with forged axle / 1984/86 F150 2WD with forged axle.
HIGH BUCK! BOB ALLEN FORD in Overland Park KS has 3 = 913-381-2999.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
Old May 12, 2016 | 04:56 PM
Hound Dog Lew
Thank you.
f-100 rick
24
May 27, 2016 09:55 PM
WhatsAChevy?
15
May 6, 2016 01:34 PM
Miller357
Jan 15, 2005 12:58 AM
