1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
03 Navigator Power liftgate and boards no showing up in meesage center and dont work
Old 05-12-2016, 07:32 AM
vector459's Avatar
vector459
vector459 is offline
I have a 03 Navigator and all of a sudden the powerliftgate stopped working as well as the power running boards. Also they are no longer in the control center where you can turn them on or off. They are not even showing up?
Any ideas? I already checked the fuses.
thanks
Old 05-12-2016, 05:27 PM
alloro's Avatar
alloro
alloro is offline
Received 4,212 Likes on 2,453 Posts
All 3 of them? #5, #105, #110
If all 3 fuses are good then the problem is a blown power liftgate module. Both the liftgate and the running boards are controlled by it.
Old 05-13-2016, 03:49 PM
vector459's Avatar
vector459
Yes I checked all 3 fuses. Ok, that's what I figured since it is not showing up in the control center.
thanks
Old 05-15-2016, 04:47 PM
vector459's Avatar
vector459
If I purchase used working module do I still have to program it from the old module? Or can I just swap them out.
If I have to use a scan tool is it only a factory ford one that will work or is there any after market ones that can do it?
thanks
Old 05-17-2016, 08:06 PM
alloro's Avatar
alloro
alloro is offline
Just swap them out...assuming the part numbers match.
Old 05-18-2016, 08:59 AM
vector459's Avatar
vector459
Ok great thank you!
Old 05-24-2016, 08:12 AM
vector459's Avatar
vector459
Parts #'s for module
My Module has a part # 4L74-14B291-AA
Every one of the used ones I have found ( I have found 5) all have the same parts # which is 2L74-14B291-AT
Do all the part numbers need to be the same or will these interchange?
thanks
Old 05-24-2016, 04:14 PM
pdqford's Avatar
pdqford
pdqford is offline
Do you have a typo within the 1st four characters?
Old 05-24-2016, 04:38 PM
vector459's Avatar
vector459
Yes sorry. I corrected the part# in the previous post.
Old 05-25-2016, 01:26 PM
pdqford's Avatar
pdqford
pdqford is offline
The 2L7 indicates the part was originally designed for a 2002 Navigator.
The "AT" on the end indicates it has had a number of revisions.
The 4L7 that was/is on your 2003 Navigator indicates it was originally for a 2004 Navigator. The "AA" on the end indicates it is has not had any revisions.
Since the 4L7 was working on your 2003, I'm guessing you could use either part.
NOTE! That's only a guess.
You might try something like Ford Parts dot com and input your VIN and see if they divulge the Ford Part #.
Old 05-25-2016, 02:52 PM
vector459's Avatar
vector459
Thanks so much for the info, I will give it a shot.
Old 05-26-2016, 07:27 AM
GTA_G20's Avatar
GTA_G20
GTA_G20 is offline
i have the same issue. Took it to the dealer assuming theyd fix it. They found a broken wire etc. VSM still isnt receivng power and therefore power tail gate is not working.
Anibal Medina
2017+ Super Duty
342
04-17-2024 04:59 PM
strtcop1
2017+ Super Duty
05-04-2019 12:21 PM
dalesatter
06-12-2010 12:34 AM
prican2000
11-16-2008 09:38 AM
Caplax40
Computer Chips & Tuners
01-20-2004 11:21 PM
Quick Reply: 03 Navigator Power liftgate and boards no showing up in meesage center and dont work
