03 Navigator Power liftgate and boards no showing up in meesage center and dont work
I have a 03 Navigator and all of a sudden the powerliftgate stopped working as well as the power running boards. Also they are no longer in the control center where you can turn them on or off. They are not even showing up?
Any ideas? I already checked the fuses.
thanks
thanks
Parts #'s for module
My Module has a part # 4L74-14B291-AA
Every one of the used ones I have found ( I have found 5) all have the same parts # which is 2L74-14B291-AT
Do all the part numbers need to be the same or will these interchange?
thanks
thanks
The 2L7 indicates the part was originally designed for a 2002 Navigator.
The "AT" on the end indicates it has had a number of revisions.
The 4L7 that was/is on your 2003 Navigator indicates it was originally for a 2004 Navigator. The "AA" on the end indicates it is has not had any revisions.
Since the 4L7 was working on your 2003, I'm guessing you could use either part.
NOTE! That's only a guess.
You might try something like Ford Parts dot com and input your VIN and see if they divulge the Ford Part #.
Thanks so much for the info, I will give it a shot.
Anibal Medina
2017+ Super Duty
342
04-17-2024 04:59 PM
prican2000
1997-2006 Expedition & Navigator
11-16-2008 09:38 AM
