Hi all,
So the basic problem is I have zero brake pressure. I replaced the wheel cylinders, filled the brake fluid, and went through about 6 rounds of trying to bleed the brakes. I followed the procedures online; I started with the one farthest from my master cylinder (right rear) and worked my way up to the closest. Every time i opened a bleeder valve it squirted fluid and i tightened it yet my Dad and I continuously got no pressure. We refilled the master cylinder after every round so we know that there is fluid going through the lines so now i need to know what my next step is? Am i doing something wrong? Am i better off sending it to a shop? I have spent a lot of frustrating time on these brakes and to be so close to finally having it on the road again only to run into this roadblock has been really annoying. Any ideas or recommendations?
Did you run your master cylinder dry? Maybe you have air trapped in the MC. Also check that the MC isn't leaking into the vacuum booster (if you have one). I had to replace mine, loads of brake fluid in the booster, the booster failed in a dramatic fashion.
If these are good air must be getting in somewhere, check hoses, make sure the copper fittings are all snug, no leaks or you'll have issues bleeding.
Try and fix yourself, these truck always need maintenance. Mine is a pain in the ***, but i'm learn something new every time something goes wrong, and it's never let me down (by that I mean i've always got it home).
It did get run dry a while back but even if there is fluid going through it when i bleed the brakes and the level in the master cylinder lowers after each round could that still be the issue?
It could be. I had to replace mine recently and in the instructions it said (in big letters) if run dry you will need to re-bench bleed.
Its not hard to bleed though. You create a loop on each outlet port back into the reservoir and push the plunger a million times to get all the air bubbles out. You need to take it off the truck to get the MC level, unless yours is level in the truck?
If the MC is pointing upwards at the front you could well have air in the MC, which would make the peddle feel spongy. I can't think of anything else based on your diagnosis. It's got to be a MC issue (air trapped).
No leaks, fluid coming out when bled, no bubbles when calibers being bled.
No worries, hope it works for you dude. I've had mine under a year a learnt a lot from this forum and the internet. Is always worth trying to fix yourself, even if you have to buy a couple of tools along the way. The way I see it, why pay someone else, i'd rather spend the money on tools and do myself
Two ideas: Speed bleeders, I have found useful after all my kids have moved out of the house. And I have found helpful to park downhill, in my driveway, to first bleed the rear, then park uphill and bleed the fronts.
Tedster9, Yes driveway works for me. I guess you could do it in the middle of the road, probably be an hour or so before the next corn combine comes by in Iowa and asks you to move. Love Iowa btw.
