driveshaft questions
Old May 11, 2016 | 05:55 PM
greentruck72's Avatar
greentruck72
so I have a 1picece driveshaft out of a 77 f150 400 c6 long bed truck, will it fit my 73 f100 390 C6 truck?
Old May 11, 2016 | 10:45 PM
HIO Silver's Avatar
HIO Silver
C6 transmissions have a 31-spline output shaft.
Check if the same rear U-joint (part number) is used in both trucks.
Measure the length of the driveshaft, centerlines the U-joint caps.
If you have access to the 77, measure the location of the transmission crossmember and verify that it is in the same position as your 73.
Post back your conclusion.
Old May 11, 2016 | 11:24 PM
greentruck72
will do, sadly the 77 got scraped, so I may just need to simply hold the 77 drive shat up to the 73.
Old May 12, 2016 | 02:40 PM
greentruck72
HIO Silver it will fit, now the question is would I be better off with the one piece or the two piece I currently have?
68AZ
Jun 23, 2018 08:23 PM
greentruck72
19
Aug 2, 2016 10:38 AM
HIO Silver
Sep 13, 2013 12:09 PM
DbleJ2010
Aug 4, 2010 09:57 AM
HardFordCore
Oct 17, 2003 11:03 PM
