Alternative solution to IC hoses popping off
Old 10-27-2018, 06:59 AM
FordTruckNoob's Avatar
FordTruckNoob
FordTruckNoob is online now
Identifies as He/Him/Noob
Received 2,923 Likes on 1,934 Posts
I have been running this for awhile now and it seems to do the trick. It is 1/8" copper rod bent into a ring to fit snugly into the groove of the stock IC pipes. The ends are silver soldered together and the ring is free to float in the groove.
Old 10-27-2018, 07:20 AM
SRBF150's Avatar
SRBF150
SRBF150 is offline
I like it! It doesn't take much, just something the clamp can seat against.
Old 10-27-2018, 07:38 AM
mueckster's Avatar
mueckster
mueckster is offline
I fabbed mine from 1/8" mild steel rod found at the hardware store metal rack. I clamped it around a pipe of smaller diameter and allowed it to overlap. I cut it to length where the spring tension of the ends butted together. I had no issues with it slipping out of the groove under pressure. Dieselsite sold them and it is where I got the idea. Since I sold my truck, I don't look at the diesel vendor sites as much and don't know if Bob Riley still sells them. They were made of stainless, IIRC.
Old 10-27-2018, 08:42 AM
Sous's Avatar
Sous
Sous is offline
Received 4,464 Likes on 2,853 Posts
@SRBF150 came up with something similar, but more simple for his CAC tubes. Next week I will be installing my T4/SXE kit and plan to have a bead added (all the way around and both ends) to the CAC tubes similar to the ones SRBF150 had done on his tubes.
If I cannot find a welder that will do that for me in short order, then I will get the rings from Diesel Site and call it a day...
Old 10-27-2018, 09:03 AM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
You don’t need to add a ring to get good clamping, all you need is a clean mating surface.
Try using Simple Green or Paint Thinner to clean the oil off Both the pipe and the inside of the boot.
once they are both oil free they will never pop off.
Old 10-27-2018, 01:22 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
DIESELSITE TURBO HOSE RETAINING RING - 3" ID BOOST HOSE
http://www.dieselsite.com/dieselsite...boosthose.aspx
Stewart
Old 10-27-2018, 03:01 PM
FordTruckNoob
Duh. It appears I have a talent for reinventing the wheel.
Old 10-27-2018, 03:43 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Yo noob..hey, you thought of something, ran with it, made it work and did the job. Let alone, didnt cost anything..success in my book for inventing/finding the... drumroll...Golden Bracelet..
Old 10-27-2018, 05:48 PM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
Spray the Tube with Hair Spray just before installing.
Old 10-27-2018, 09:36 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
I actually use hairspray. 😁Haven't blown a boot off yet.
Old 10-27-2018, 10:08 PM
mueckster's Avatar
mueckster
Are you using the one labeled "Extra Hold"?
Old 10-27-2018, 10:36 PM
schlepprock250
LOL.. Yep 😁
Old 10-28-2018, 06:09 AM
FordTruckNoob
Thanks timmyboy76. This isn't the first time I have done dumb **** so I am okay with getting called out on it.
Old 10-28-2018, 08:56 AM
mueckster's Avatar
mueckster
No need for name calling. Necessity is the mother of invention. You created something that worked for you. Lots of people have like ideas and it's not surprising that others have done similar things that worked for them. I, for one, have seen the ideas of others and put my own twist on it. Maybe not always an improvement, but something that served the same purpose. Everyone can see that there are options and others can find what works for them. Thanks for sharing!
Old 10-28-2018, 09:24 PM
Stewart_H's Avatar
Stewart_H
Oh no bro, not like that at all. I wasn't calling you out, just letting people know where they could get one if they liked your idea.
No matter how popular something might be, there aint no way something can be known to everyone.
Stewart
Quick Reply: Alternative solution to IC hoses popping off
