Compression test, pull fuel relay?
Old May 10, 2016 | 09:11 PM
Dean06919's Avatar
Dean06919
If I have time, I'd like to do a compression test on my 1994 and 1996 F350's (351 and 460). If I remember correctly, the fuel relay is under the hood, by the drivers side, right? Also, do I need to pull it, I seem to remember that when the throttle is wide open, the computer shuts off fuel anyway. Is that correct?
Old May 11, 2016 | 08:42 AM
Phy's Avatar
Phy
If you leave the key off, and jump the starter relay to turn the engine, you don't have to worry about it.
Old May 11, 2016 | 10:00 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
It's in the same block as the DLC connector and trailer tow relay (if equipped). Right behind the air filter box and PCV breather tube. Yes, you can pull that and that will kill both fuel pumps for your test. Remove spark plugs and block throttle wide open, crank each time for ~3 seconds. As long as the lowest reading is at least 75% of the highest reading generally you're ok.
Old May 11, 2016 | 01:11 PM
sgip2000's Avatar
sgip2000
You can disconnect the coil too.
jsmallwood_2000
55
Jun 7, 2018 10:11 AM
Chefsteele
Jan 10, 2014 07:39 PM
dougf2504x4
15
Jul 29, 2009 09:20 PM
Sycostang67
General Automotive Discussion
Nov 1, 2008 10:37 AM
donald campion
Jan 2, 2005 11:48 PM
