fuel leak
Old Aug 14, 2003 | 09:25 PM
bighills's Avatar
bighills
fuel leak
after my 87 f350 sits overnight it starts within three cranks but only runs about 15 to 30 seconds and dies then it just does not want to start so i have to bleed injectors every morning. has to be air any idea where to look first??? thanks for any help..
Old Aug 15, 2003 | 06:28 AM
bilder12's Avatar
bilder12
fuel leak
Watch the oil level and that will tell you if the lift pump is leaking, but there should also be fuel out the weep hole there. Maybe one of the injector caps has a bad o ring or even the injection pump is leaking - there is also a weep hole beneath there. But it sure seems like the lowest point is the problem.
Old Aug 15, 2003 | 05:20 PM
bighills's Avatar
bighills
fuel leak
thanks for help i will start with that and let you know what i find..
