Hey guys and gals, got a question concerning a steering problem with my '95, 4wd, 302, Ext. Cab Eddie Bauer. 251,000 miles.
It's regarding memory steer. I've changed tie rods, drag links, shocks, springs, had major alignment work done.
Problem is, that the memory steer is wearing me out. I tried adjusting the sector shaft and that it helped a little. And I didn't want to do that...but that's besides the point....
The truck has unknown ball joints. They aren't bad or I would have changed them before the alignment work. My question is whether or not they ARE bad and maybe binding? I'm gonna assume 10 years they have been on there or within 10 years. They are greasable.
Is there a definitive way to check them or an answer for " Yes, this is due to ball joints binding".
It's only 2 things left for this problem. Steering box or binding ball joints.
If the weather holds out for the weekend, I plan on putting new ones in if that's the problem. I just want to get them ordered quickly from RockAuto.
U-joints in the knuckle are good. Can't find any problem with them.
So you had the spindle off and pulled the shafts out to check the u joints? You can also jack one side up, lock the hub turn the wheels full left or right and spin the tire. If the ujoint is bad it will eventually bind and make the tire difficult to turn. Lower it down and repeat on the other side. I'd start here, because it is the simplest to do. And it is exactly what caused my memory steer.
Jack the truck up and disconnect the tie rod and see how hard it is to turn the wheel by hand. Shouldn't be very hard.
Don't forget to check the ujoints in the axle shafts for bind, they can cause steering issue too.
My steering wouldn't return to center. I disconnected the tie rod end and tried to turn the wheel. I could barely move it- even kicking the wheel it wouldn't move. I should have done both sides because I only did the passenger side. The following year I ended up doing the driver's side.
It doesn't isolate the u joints from the ball joints. One thing you could try, lock hubs in and drive tight circles in a dirt lot. If things improve, you know the u joints were bound up. Worked for me, and the joints had rust dust coming out of the caps after that. Unless the ball joints were torqued incorrectly, they tend to get loose over time and not tight. As noted above, trying to rotate the tires with front end in the air with hubs locked is another good test for the u joints.
U-joints were replaced in the past. I can turn the steering knuckle and rotate the freely.
The steering knuckle itself is taking nearly all I have to turn them side to side. I'm pretty stout and I don't remember ball joints being so tight in the knuckle that I have to bear them to rotate...
How long ago were the u joints done? At 240k, I'm on my 3rd set. Spicer joints nonetheless. Just don't want you to assume ball joints bc you've assumed u joints are okay.
I totally understand what you mean.
Here's some more info...
I started working on the passenger side knuckle, using lots of PB Blaster and a flat head to clean grease and debris from the the BOTTOM ball joint boot. Started shooting some grease in and the knuckle is started to slowly ease back and forth. It's WAY better than the driver side, at the moment. I'm about to repeat the same thing to the driver side.
No idea when the u joints were done. They move freely and effortlessly. I've done theon my other trucks and these seem to be good.
I did notice turning the steering wheel, it's tight in center. But, in other directions, it spins smooth! So...steering box perhaps?
I found the jam nut for the bottom driver side ball joint loose. No need to force much, and it came loose, easy....
As I was loosening the adjustable camber bushing, the knuckle became a lot easier to turn and without the bushing, it's super easy.
I'm wondering if the adjustable camber bushing is at fault. As it sits, I'm close to pulling the steering box and installing new ball joints so I can have a fresh start at this.
