T18 transmission problems.
Old May 7, 2016 | 04:27 PM
Marc Creason's Avatar
Marc Creason
I have an 1981 Ford F250 with a t18 transmission. The transmission suddenly disengaged while driving on the highway. I assumed one of the syncro rings was bad. I rebuilt the transmission and on the finish test drive it worked as normal. I went to return the transmission jack and the same issue still exsists. Could it be something other then the transmission
Old May 7, 2016 | 06:55 PM
The Frenchtown Flyer's Avatar
Maybe the detents on the shifter / linkage are incorrectly set. Short of that I'd say the synchro dogs on the gears are shot, or the snap ring holding the gears on the mainshaft has broken. Been there..
Old May 10, 2016 | 12:38 PM
AbandonedBronco's Avatar
AbandonedBronco
Hello Marc, and welcome to the forums.
Is your truck 2WD or 4WD?
If it's 4WD, your transfer case could be popping out of gear.
arkiados
Oct 29, 2017 09:59 PM
STANGIN
Dec 30, 2004 08:59 AM
skips69
Dec 29, 2002 01:52 PM
gimps
Dec 7, 1999 07:40 PM
