Shaking at idle
Old May 6, 2016 | 02:43 PM
Cmbyrd's Avatar
Cmbyrd
Shaking at idle
Just bought 1978 F100. Been changing plugs, cap, wires, fuel filter trying to get it running better. Adjusted carb so it would run better. Now it shakes at idle. Any ideas what to look at next?
Old May 6, 2016 | 02:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ck your spark plugs wiring for being correct and sounds like the carb adjustment might be off.
Old May 6, 2016 | 03:25 PM
HIO Silver's Avatar
HIO Silver
What "shakes"? Do you mean the engine seems is misfire and shakes with an uneven frequency?
Does the engine surge?
Old May 6, 2016 | 03:45 PM
Cmbyrd's Avatar
Cmbyrd
Engine shakes when at idle. Then it will run smooth for a few seconds. Then start to shake again. So I guess that would be considered surging. I feel stupid asking simple questions. But I always wanted an old truck, just never done much mechanic work.
Old May 6, 2016 | 04:17 PM
Cmbyrd's Avatar
Cmbyrd
Checked the wiring and it's correct. Backed out adjustment on carb and it's running much better. Thanks.
Old May 6, 2016 | 09:47 PM
hasteranger's Avatar
hasteranger
What did you adjust? Mine does that sometimes.
Old May 6, 2016 | 09:50 PM
Cmbyrd's Avatar
Cmbyrd
I backed the carb adjustment screws out 1/2 turns each.
Old May 6, 2016 | 10:46 PM
orangeford's Avatar
orangeford
In order to correctly setup your carb, get a vacuum gauge and hook up to a manifold vacuum source. Adjust idle screws until max vacuum is achieved and try to adjust each side evenly. To start out you can turn them all the way in and back out about 2 1/2 to 3 turns and then go from there with the gauge. When you find highest vacuum turn the screws back in until it drops and then back out to highest vacuum.
It will run best there.
brknight
Jul 31, 2011 04:32 PM
chimpbike
Jun 11, 2007 09:19 AM
77monster
Aug 1, 2003 10:32 PM
bodyelite
Sep 18, 2002 05:38 PM
