Sponsored by: Real Truck
Hail Damage
Old Apr 2, 2017 | 08:33 AM
GN1220's Avatar
GN1220
My Uncle bought a black Mercedes that was beat to hell from hail. The hood, roof, trunk, even the tops of the quarters had dents. A day or two and $800 later the car was flawless. Not one sign of any damage whatsoever and the biggest plus in my eyes is the fact the car hasn't been painted on and still retains all of it's original sheet metal. Those of you suggesting cutting the roof off of a brand new truck and trusting the body shop to get the seams sealed, door gaps and everything else perfect have a lot more faith in the body shop than I do and need to go watch a PDR guy in action. And good luck explaining to the next owner that you had the entire roof cut off just because of a few hail dents. That would raise a huge red flag in my book.
Old Apr 2, 2017 | 09:21 AM
The Bone's Avatar
The Bone
I have had PDR done on 2 of my cars. The guy did a great job.
I would not cut the roof off my car by some body shop. i know how they work and it's not like on tv. Those guys care about cars. Body shop guys care about getting the car in and out as fast as possible. its only $$$ to them.
It helps to take the truck apart so the dent guy has access to the dent from both sides of the metal if possible. Sometimes the suck the dent out and sometimes they push it out. Depends on the dent and where it is.
Old Apr 2, 2017 | 10:28 AM
sur48's Avatar
sur48
I agree keeping the original sheet metal is would be best option for a few completely pulled out dents but O.P. just states a"a lot of tiny dents" So with that a little tiny dent here in the Florida sun over time can cause a issue. Again 20 or more dents would make you remove roof? Your back again even if one dent turns into a hole it would be a bad think. May be best bet to see if insurance would allow the cost of repair and diminish value and trade to another truck .
Old Apr 2, 2017 | 02:37 PM
Jafo56's Avatar
Jafo56
Not hail damage but years ago I had a 1994 Lincoln mark 8 it had a door ding in the side about the size of a soft ball....( no crease). The paintless guy agreed it was pretty bad and said he could get about 90% of it out.....he gave it a try and you couldn't even tell there was any damage at all..... I was impressed
Old Apr 2, 2017 | 03:04 PM
RV_Tech's Avatar
RV_Tech
We had a really bad hail storm here about ten years ago and the PDR guys came from all over the country and worked here for weeks. It took about two weeks just to get in. One time I had about 40 dents pulled, other times less, but always several. Perfect every time. The place I most often used is really straight up and will tell you whether he thinks he can fix it. I use an excellent body shop for other work, but for things like hail damage, they say to just get it pulled. Just no reason to go through the sanding, etc., if it can be pulled.
Has anyone reading this thread who has actually used PDR and has first hand experience had any problem with it? So far I am not reading any negatives from folks who have used it.
Old Apr 2, 2017 | 08:52 PM
Unclemark's Avatar
Unclemark
Originally Posted by sur48
My thought is years after beautiful dent less repair of the sun beating the heck out of fillers on the roof little hairline cracks may appear for water to get trapped in and then a rust hole . With a fully replaced metal roof new paint it s all brand new no dents no holes and all the rain, due, ect. water will run right off as new design intended.
I see what your​ saying now..... If you go paintless dent repair there will be no body filler used but if the dent is bad and the paint ends up breaking or cracking away from the metal then the filler and body work and paint come in play but if done correctly by a good shop you should never know there is filler there. Filler to fill big dents is wrong all the way around it needs to be body worked to get smooth and then the​ filler to make it invisible.
Old Apr 2, 2017 | 09:52 PM
GN1220's Avatar
GN1220
Neither of these comments makes any sense whatsoever. Go PDR and be done.
Old Apr 3, 2017 | 04:13 AM
Unclemark's Avatar
Unclemark
All my experience with have been good with PDR. I used to work at a bodyshop on the side years ago and have watched my buddy that does PDR for a living and seen him work wonders with badly hail damaged cars to were you couldn't see any flaws once he was done. It's​ pretty cool to watch it being done. He did say it's getting more and more difficult as vehicles are getting more cheaply made with really thin body panels.
JeffHann74
2009 - 2014 F150
37
Mar 24, 2012 10:10 PM
IslandBlueV10
Paint & Bodywork
Jun 17, 2011 05:43 PM
xjcamaro89
2004 - 2008 F150
22
Jan 27, 2010 01:12 PM
texcan
Feb 9, 2008 05:53 PM
RyanMiller
Sep 15, 2004 07:38 PM
