Help identify axle
Old May 4, 2016 | 12:48 PM
Ford3+'s Avatar
Ford3+
Help identify axle
Hey can anyone help me ? I am new to all this and I have a 1982 Ford single cab f250 that has a broken front axel I need help identifying the front axel . I am told I ether have a Dana 44 or 50 probly 44 the way hub looks and all . my big question today is will the axel from a 1980 Ford f250 match ? I am including a picture of the 1980 tire and hub to see if anyone can identify it becouse it looks different then the pictures I have seen of 44vs50 hub ratio in a thread I saw on this sight . also the picture of blue fender is my 1982 ford f250 single cab that i am also looking for confirmation or help identifying it in order to find a match if the 1980 will not match up ..any help would be awesome . I'm a newbie at all this so any help will be much appreciated.
Old May 4, 2016 | 09:24 PM
Nothing Special's Avatar
Nothing Special
The hub looks like a Dana 44HD to me as well, but I'm not as sure as I would be if the decorative cover wasn't hiding where the hub comes through the wheel (the Dana 50 pretty much fills the hole in the wheel, the Dana 44 has a lot of clearance).
I think an '80 F-250 could also have either a Dana 44HD or a Dana 50 as well (if others here know better I hope they'll correct me). If I'm right about that, whether the '80 axle would work in your truck would depend on which axle that truck has too.
Old May 4, 2016 | 09:32 PM
DeereFord300's Avatar
DeereFord300
I thought that the regular cab F250 only came with the 44HD til the F350 was switched from using the 50 to the 60, then the F250 gained the 50 as an option?
Old May 4, 2016 | 10:27 PM
82F100SWB's Avatar
82F100SWB
That is definitely a 44hd on the blue truck.
First picture is a rear?
Old May 4, 2016 | 11:43 PM
Ford3+'s Avatar
Ford3+
Yes sorry the guy sent me a pic of the rear axle on the 80 by accident I went and looked at it today would this be a match ?. ill load pic here
Old May 5, 2016 | 03:12 PM
Ford3+'s Avatar
Ford3+
Thank yeall for all the help it really helps !! One more question if you dont mind is this 44 or 50 ?if it is 44 ( which is what I think it is ) will it still match my 82 (the blue truck ) if it's out of a 86 ?
Old May 5, 2016 | 06:34 PM
Boombastic86's Avatar
Boombastic86
I'm sure you have probably checked this, but if you haven't, make sure the gearing matches that of your truck.
Old May 5, 2016 | 07:07 PM
Ford3+'s Avatar
Ford3+
Ware exactly to I check gearing ? I'm new to all this . everyone I talked to just seems like easy swaps and such not sure of details .
Old May 5, 2016 | 07:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You check the gearing by reading a metal tag bolted to the differential housing, or by jacking it up in the air and making a mark on the wheel and on the pinion.
Then you determine how many times the wheel goes around for the pinion to make a revolution.
I.e. a little more than four times equals 4.10 gearing. Three and a half times would be 3.50:1 gears
F250 super cabs came with the D50 front axle.
Any other 250 would have to be ordered that way as part of a plowing package or something.
Old May 6, 2016 | 01:33 AM
82F100SWB's Avatar
82F100SWB
All of the hubs you have pictured are 44hd's. If you just need a shaft, gear ratio isn't important.
However, if you need the pass side inner at the diff 80-82 axles have a bolted on retainer and pressed on bearing while the later trucks have a c-clip.
Old May 6, 2016 | 07:15 AM
Ford3+'s Avatar
Ford3+
I just need the driverside shaft I think it cracked right at the start of the fork . I'll include pic . so if I'm reading g right if I just need the shaft ratio does not matter ? Nor will it matter if from a 86 ?
mrfix71
27
May 9, 2022 08:58 AM
Hogtrapper
19
Mar 25, 2015 12:34 PM
BIGMAGGOTBILL
Feb 17, 2014 12:51 PM
eriklane
Sep 11, 2013 09:13 PM
dandshon
Jul 29, 2003 08:00 AM
