Sponsored by: Real Truck
Which parts?
Old May 4, 2016 | 01:32 PM
spadey's Avatar
spadey
Which parts?
Hello everyone, long time lurker first time post.
Ok I have a f-450 2005 6.0 / 87,000 miles
I have a couple questions and need to know from you experts!
1. Which oil cooler do you recommend dorman or oem?
2. What coolant filter is recommended? Dieselstop?
3. This truck is a tow truck so I want to know also what the benifits are of just doing an updated egr cooler from bullet proof diesel vs egr delete?
The reason I ask these questions is my local shop is recommending a dorman oil cooler and no need for a coolant filter. From what I have read dorman has problems or at least from what I read in older 2010-2012 posts. So what the current situation with these and from what I read coolant filter is a must. Correct?
Please let me know, thanks
Old May 4, 2016 | 03:13 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
1. Only use the OEM oil cooler kit, Dorman used to ship with a gasket that broke down when exposed to oil and would send bits of gasket through the HPO system. Inexcusable failure and I don't care if they send a different gasket now it's just not worth the risk with $1,600 in injectors on the line. The IPR valve is $150 and can be destroyed by the gasket parts. What the video in this post:
https://www.ford-trucks.com/forums/1...l-coolers.html
2. It doesn't really matter, all the bypass setups do the same thing, and really don't do much unless you have a ton of casing sand. Changing to a Cat EC-1 rated ELC coolant that's sillicate free and distilled water instead of using Ford Gold and tap water will net a better result with a lower likelyhood of the new oil cooler having a silicate gel problem. I have a filter, never really got anything out of it. Honestly I don't think it's must have.
3. Not sure there are any benefits to keeping vs deleting unless you have inspections. You can weld the cooler shut and leave it in place and avoid having to buy a kit or replace the up-pipe.
Old May 4, 2016 | 03:37 PM
spadey's Avatar
spadey
Ok. Oem oil cooler it is!
I think I'm just going to put a coolant filter on just for peace of mind. I totally for got that the egr cooler could be welded shut. Thank you for the reminder!!
Couple more questions and I'll be happy with what I decide.
1. Anybody have the upgraded oem oil cooler part#?
2. Is there a how to on where and how to weld the egr cooler closed?
3. The cat-ec1 ELC is what that coolant is called?
Big thank you to Texastech and to all that's helps me out!!
Old May 5, 2016 | 11:31 AM
texastech_diesel
Token Redneck
Oil Cooler:
Oil Cooler Kit - Riffraff Diesel Performance
EGR welded plugs:
https://www.ford-trucks.com/forums/1...l#post13303706
EC-1 is the rating specification. Multiple brands of coolant meet that spec, jsut google "coolant ec-1" and you'll find several. I use Zerex:
Valvoline? ZEREX? Extended Life Antifreeze / Coolant : Product Catalog - Valvoline®
Rotella brand:
Shell Rotella ELC Antifreeze, 1 gal. - For Life Out Here
NJEx
Apr 15, 2018 11:39 AM
caskillet
Mar 20, 2013 10:19 AM
Canadianpowerstroke
Oct 14, 2012 06:49 PM
FICMrepair.com
Jun 16, 2011 06:53 PM
paulkcbulm
Jul 25, 2010 10:07 AM
