hfcm issue
Old May 2, 2016 | 07:26 PM
Chan5411's Avatar
Chan5411
hfcm issue
Hey guys, I've tinkered around with this issue for awhile but never really dug deep into it intelligence now. The issue I'm having is the fuel pump occasionally (more times in colder weather, or a short drive.) stays running untell I pull the fuse or let the truck idle for 30 minutes or so. I've pulled every relay, swapped relays thinking I had on sticking but no luck.
Has anyone else ran into this problem? If so please share!
Thanks
Old May 2, 2016 | 09:45 PM
FiznUKa's Avatar
FiznUKa
Just one question where is the sound you are hearing? Is it in the frame under the driver door or on the passenger side wheel well.
Old May 2, 2016 | 09:54 PM
Chan5411's Avatar
Chan5411
Driver side, on the frame. I can put my hand on the pump and feel it on
Old May 3, 2016 | 01:08 AM
Yahiko's Avatar
Yahiko
That relay can't be gotten to with disassembly of the CJB.
One thing to do before disassembly is look up under the dash
to the top where the window glass fram is and see if you see any
rust. If you see rust I would also get the glass removed and
resealed so that any water won't run down onto the CJB and drive
you crazy with problems like this.
Your in luck I posted some photos of a CJB from an 05.
You need some small flat blade screw drivers to unlatch the back
from the front and then it just lifts off. Also if you look at the back
you can see a hump on the back between connectors and that is
right over the relay pair. If I recall one is the fuel pump the other
is part of the starting system.
Not sure which one it is but here are the two relays that you can't normally
replace. Not saying that you can't but it's not easy.
Also the nut that holds the main power cable onto the CJB is staked so it's
very hard to remove and may even damage the bolt some.
Sean <BR>
6.0L Tech Folder
Old May 3, 2016 | 09:24 AM
Arizona97's Avatar
Arizona97
Thanks Sean, great information, I will keep this for future (I hope I don't need it).
Ed
Old May 3, 2016 | 11:21 AM
Chan5411's Avatar
Chan5411
As much as I work with electrical and Plc crap for work It never crossed my mind about busting the cjb apart and inspecting it.
When I get off today I'll give an update on what my findings are
Old May 3, 2016 | 03:05 PM
Chan5411's Avatar
Chan5411
There is what my cjb looks like. So is the middle relay the one I'm after?
Old May 3, 2016 | 03:06 PM
Chan5411's Avatar
Chan5411
I also found no rust up under dash.
Old May 3, 2016 | 04:04 PM
Yahiko's Avatar
Yahiko
2006 truck? Should have 2 not 3. Unless you also have the fuel heater still.
I'll post some diagrams that will show what pins to test.
That way you should be able to locate the beast.
Look at page 2 left side and you will see the pump relay.
I'll have to get at some files on the other computer and post
the plug diagrams to make the job easier on you. That will be tonight.
Sean <BR>
6.0L Tech Folder
Old May 3, 2016 | 11:08 PM
Yahiko's Avatar
Yahiko
Ok you want to look at CC270a, C270f and maybe C270h
Sean <BR>
6.0L Tech Folder
48fordcoe
Mar 25, 2009 12:33 PM
7283-F250
New Hampshire Chapter
24
Aug 8, 2008 08:17 PM
